Old 11-05-2010, 02:15 AM
razorspells razorspells is offline
IRA-3 IR Receiver
Just wanted to ask for some advice about the IRA-3 IR Receiver from Homelectronics? Anybody using this device with EventGhost? Is it a good alternative to USB-UIRT?
Thanks a million...
http://www.home-electro.com/ira3.php
Old 11-18-2010, 08:56 AM
kamikaze2112 kamikaze2112 is offline
this is pretty much exactly what I'm looking for. I'd like to know how this thing works as well.
Old 11-18-2010, 03:52 PM
sTVb sTVb is offline
I have an IRA-2 and it worked fine when I used it. I replaced it with a MCE receiver when I had to replace my wireless keyboard.
It looks like they've fixed the main annoyance from the IRA-2 which was the stiff hard wired serial cable.
Keep in mind, its a receiver only- you have to get the tIRA or USBUIRT if you need to control anything with it
Old 11-19-2010, 10:12 AM
already have a usbuirt for blasting the stbs back in the office, i need something wired to live in the living room
i went and ordered it anyway, since it was only about $40 shipped. got it today, will report back with my findings as soon as get a chance to play with it
Old 11-19-2010, 07:54 PM
So I got this thing up and running.
Don't bother with Girder unless you already know what you're doing with it, it's confusing as hell. I played with it for over 20 min and couldn't get anywhere with it so I downloaded Eventghost.
Eventghost works fantastically with this device, and works really well with sage. the only thing I haven't got working properly is the key repeat, which is going to take some fine tuning, but it was stupid easy to assign the IR codes from my Hauppauge remote to the SageTV macros. setup with Eventghost took me about 20 minutes to get good functionality.
I've got it extended over about 70' of cat5 and it works great.
My only gripe is that the talk back LED stays on all the time and blinks off when you use a remote, imo it should be the other way around. you can turn it off completely with the config utility from their website.
overall, this device solves my problem, was cheap, and very easy to set up
Old 11-20-2010, 08:55 PM
@kamikaze2112 & @ sTVb - Thanks for the feedback, I already ordered mine, and will be using eventghost with it.
I would also like to add that their customer support quickly responded to all of my questions.. excellent response time...
Old 11-24-2010, 09:44 AM
if you need any help setting it up, lemme know.
Old 12-01-2010, 09:55 AM
Got my IRA 3 receiver w/ cable today and I would like to report back...
- Installation was easy (I'm on WinXP), no driver needed, instruction leaflet included
- Has an LED indicator so you can see it's working
- Works with EventGhost (UIR/IRman and SageTV) plugin
- Works with any IR remote control
- A cheaper alternative to USB UIRT if you only need a receiver.
- Excellent response time on customer inquiries
I give this device UP!!
Which IR Receiver AWS Hardware Support 3 01-19-2010 02:24 AM
Can I use USB UIRT or IRA to control Sage Extender which is in closet personalt Hardware Support 5 06-28-2008 05:57 PM
Do I need a receiver? garyellis Hardware Support 5 02-11-2007 10:24 AM
IRA-3 Serial IR Reciever? polarhyte Hardware Support 0 10-01-2005 11:13 AM
Which IR receiver to use? jhh Hardware Support 2 01-18-2005 09:03 AM
