Old 09-08-2011, 04:17 PM
willieb willieb is offline
What does this property do?
From the 7.0.9 beta announcement:
32. Added property "seeker/fs_mgr_wait_period" which controls the delay between when capture device recording progress is checked (in milliseconds, defaults to 15000)
Can anyone help translate that? It isn't clear to me from the description. Instead of saying it controls the delay between A and B, i am reading it to say it controls the delay between A (the B is missing). I will just change the property when I get home and see what it does but I thought it couldn't hurt to ask before then. I am wondering if increasing the number might help with some bogus halt detected errors I have been getting.
Old 09-08-2011, 07:29 PM
sleonard's Avatar
sleonard sleonard is offline
The way I read it is that Sage checks the recording progress every X milliseconds. You can change the value of X milliseconds using this property. I assume that checking the recording progress means looking at the file size to make sure it is growing but there are other things it could check instead.
S
Property files chrishallowell SageTV Studio 2 08-23-2010 12:11 PM
When setting or getting property PLUCKYHD SageTV Studio 19 05-12-2009 03:04 PM
added property ...... where?? Stuntman SageTV Beta Test Software 0 02-01-2008 12:42 AM
experimental_video_thumbnail_generation property? popechild SageTV Software 7 06-29-2006 05:30 PM
What is this new property? mlbdude SageTV Beta Test Software 22 04-07-2004 09:23 PM
