Anyone running Java 7 Update 5?
My Sage server is still running Java 6 Update 33 and I was thinking about updating, but wanted to check and see what experiences others have had.
No problem here
No Problems So Far....
I've updated to Java 7 update 4.
So far Sage and Java have played nice together. But I did search the Sage Forum before doing it because folks had problems with the installation of Java 7. |
Java 7 update 5 works fine for me, but I seem to get memory leaks when using it.
I've never actually had sagetv crash, but monitoring my java heap size I've been seeing that after running for around a week it'll get up to around 400-500 mB with the max usage using everything available (1050 or so with mine). With Java 6 update 33 after a week I'm still only around 200-300 mB current (with nothing recording or playing) and around 500-600 mB max. My install as almost no plugins (just multi-function stop). I'm using an hd-pvr and hvr-2250 tuners with a single hd300 to play back the recorded media. |
I installed it and I have a problem with Sage now not using my regional settings correctly - using a 12 hour time display format instead of 24 hour. I probably have to downgrade.
java 7 update 5, but every morning at about 3:30 am I restart the sage service - so that I purge the memory (also so that my backup runs, without the sage service running) -- if I don't my JVM total memory drops to about 100,000 M and the sage screens are extremely slow on all my extenders. After the restart it pops back to above 980,000 M, my max is 1,267,072 M.
SERVER: Dual Core Xeon 3.0GHz 5160, 8gb RAM, Win7 x64, SageTV 9.0.13.536 w/ BMT, WebUI, OpenDCT, Java 1.70_79 TUNERS: 2 x Ceton PCIe InfinitiTV - FIOS STORAGE: UNRAID - 8tb for archived shows, DVDs, pictures and music CLIENTS: 2 x HD200s, 2 x HD300 |
Tried updating a desktop PC (Win7 32) to 7u5 and got the following error messages: MSVCR100.dll file missing, and can't find JVM.dll file So I uninstalled the latest java and went back to 6u30 on the desktop which is working fine. Since 7u4 works on the laptop, its probably a user error causing the problem on the desktop but was easier to go back to the earlier version than to spend more time trying to figure out why 7u4 (or 7u5 for that matter) won't work on the desktop. My server is still running 6u29. I found this utility to check the java version: http://www.javatester.org/version.html
Headless Server: Q8400 2.66ghz / MSI P45 Neo2-FR / 4GB Storage: 120 SSD for SageTV / 3TB for TV recordings / Unraid NAS 5TB for vids, pics, music w Plex Docker Tuners: HDHR3 x 2 Extenders: Nvidia Shield x2 / 3 placeshifters Server Software: Win 10 64, SageTV 9.1.5.683, Java 8_241, Real VNC Other: MiniClient, Commercial Detector UI, Sage Recording Extender |
http://www.microsoft.com/en-us/downl...s.aspx?id=5555
Windows 10 I3 Dual Core 3.0 Server, SageTV9... OpenDCT with 2 HDHRPrimes and 4 HDHRconnects for a total of 14 Tuners. Last edited by nyplayer; 07-02-2012 at 10:21 AM. |
I've had no problems with sage until trying to load java 7.5.
Also uninstalling 7.5 and installing 6.32 did not fix the problem. So I restored my computer and tried again. Had the same problem with MSVCR100.dll and jvm.dll I left java 7.5 on my machine, but I copied the msvcr100.dll file from java bin folder to my windows system32 folder and everything works. |
nyplayer - your solution worked perfectly. Many thanks. Last time I upgrade JRE on this box...
Yeah .. I completely removed all my old java versions and am running nothing but 7 on all my machines. Also it is always a good Idea to have the latest "run times" because other applications might require them... best way to avoid headaches in the future.
Windows 10 I3 Dual Core 3.0 Server, SageTV9... OpenDCT with 2 HDHRPrimes and 4 HDHRconnects for a total of 14 Tuners. |
Java 7.5 problem??
![]() I have downloaded the MS Visual C++ 2010 Runtimes you linked. But I still cannot start SageTV. I still get the error messages you originally cited regarding MSVCR100.DLL and jvm.dll I am in way over my head and I apologize for such. Can you help me get SageTV running again? |
After download did you Install the runtimes.. That download is just a web Install you have to double click it and Install.
You can try just Stopping the service and Installing runtimes and restart the service. If that doesn't work see below. 1. Stop the SageTvservice. 2. Uninstall Java (all) 3. Install the runtimes. 4. Install Java 5. Start Service.
Windows 10 I3 Dual Core 3.0 Server, SageTV9... OpenDCT with 2 HDHRPrimes and 4 HDHRconnects for a total of 14 Tuners. Last edited by nyplayer; 07-08-2012 at 12:06 PM. |
Anyone using This version with Sage MyMovies?
I have been frozen at Java 6.29 because of needing MyMovies. Does anyone know if the later versions have the same incompatibility?
Sorry I do not use MyMovies maybe you should Inquire in that forum.
![]() It was only in the last few days when my SageTV abruptly quit working that I discovered to my horror that SageTV is no more and I completely panicked. So your expert help was far more valuable to me than you probably imagine. ![]() |
I recently updated to 7u5, and My movies appears to be working just fine. I needed to reboot my server after the update, but other than that, all was well.
thanks for the input guys. I will probably try and update in the next couple of weeks and post my result.
This space intentionally left blank |
See this site http://www.sagetv.com/IntegrateVBDot...udio_Curr.html
Java Heap running low after 12 hours | redbaron73 | Diamond | 8 | 05-12-2011 03:42 PM |
Java 6 Update 19 | wacole | SageTV Software | 18 | 05-12-2010 05:19 AM |
What Java Versions Should We Be Running? | RAlfieri | SageTV Beta Test Software | 5 | 03-02-2006 06:19 PM |
Java VM Crash Running as Service | RAlfieri | SageTV Beta Test Software | 2 | 10-03-2005 06:58 PM |
Need to update Java? | Opus4 | SageTV Beta Test Software | 13 | 01-29-2004 09:21 AM |
