Old 03-20-2016, 02:09 AM
jarredduq's Avatar
jarredduq jarredduq is offline
Location: Stockton, CA - Most miserable city in the USA, SageTV makes it bearable
Windows problem with browsing SMB import
Hello,
I had to rebuild my machine from scratch after upgrading some components. I had backed up my sagetv directory. Everything is working okay, except my media folder on my NAS. I'm getting invalid directory errors when trying to browse network shares.
I attached a screenshot. I'm running windows 10 pro 32-bit and SageTV 9.0.4.232.
Please advise and thanks in advance!
Edit:
If there is something I can provide (logs, etc) that can help trouble-shoot this, please let me know. It's been a long time since I've had any issues with my Sage setup.
Server: HP w/Intel i7-4770S CPU @ 3.10GHz , 500GB SSD, 16GB DDR3, Win 10 64-bit, 4TB of SSD for recording
SageTV: 9.2 - 64-Bit
Capture Devices: 2xHD Homerun Prime and HD-PVR (Comcast Premium/Music Channels)
Client 1, 2, 3, and 4: HD200.
NAS: Synology DS220+ 8TB (Movie Storage)
Sage Add-ons: Jetty, Neilms Webserver (Jetty), Mobile Web, Play-On Plug-in, Comskip Plug-in
Old 03-20-2016, 10:14 AM
Skirge01's Avatar
Skirge01 Skirge01 is offline
I've never been able to browse UNC paths in Sage. However, if I type in the full path, it works just fine. I see you're prefixing with smb, which I'm used to entering for my own shares when using Kodi, but never that way in Sage. For Sage, I use the Windows format of "\\[server name]\[full]l\[path]".
Software: SageTV 7
Old 03-20-2016, 10:41 AM
jarredduq's Avatar
I tried that as well and it didn't work. This issue has really beat me up.
Old 03-20-2016, 11:18 AM
I found I had to add "Everyone" to the Security tab on the folder that is shared with Full rights to get rid of the "Invalid directory" when browsing from a linux server to a windows directory - maybe that will work for Win10 as well.
Old 03-20-2016, 11:58 AM
Skirge01's Avatar
Were/are you running Sage as a service? If so, did you remember to change it to an account with admin rights?
Software: SageTV 7
Old 03-20-2016, 04:10 PM
jarredduq's Avatar
Thumbs up
That fixed it. On my WD MyCloud I had to set the share to public. It must be a Windows 10 thing.
Old 03-20-2016, 05:34 PM
Glad it worked for you.
Browsing for files problem nyplayer SageTV Beta Test Software 3 05-21-2010 06:56 PM
DVD Profiler Import problem sflamm SageTV Customizations 1 04-13-2009 08:13 AM
Cover Import Problem Taddeusz SageMC Custom Interface 2 09-16-2008 04:33 PM
Windows XP MCE 2005 and Simple File Sharing to Windows XP problem perfessor101 SageTV Software 1 01-14-2007 10:52 AM
Import Playlists and Music Jukebox Import Problem extreme.paradox SageTV Software 3 12-29-2004 03:00 AM
