SageTV for unRAID/Docker Discussion related to SageTV for unRAID/Docker. Questions, issues, problems, suggestions, etc. relating to SageTV for unRAID/Docker should be posted here. |
Quick question about sagetv docker
I'm playing with unraid right now but I have a quick question about the sagetv docker. Is it a full Linux install with sage included? The reason I ask I saw docker has a windows docker system and an interface called Kitematic for running dockers. I thought I may also try that since I will have to have a windows instance running to use my HD PVR 2 anyway.
All that being said, if you get all that to work, and are happy with the performance, you will likely still be out of luck with the HDPVR v2. Just because you are running on Windows... you are still running on Linux, and linux would need the drivers, and it doesn;t have the drivers for V2.
No, I was I planning to run it as a network encoder that is why I need the windows install either way. I know there are drivers for HD PVR2 but they don't use the standard for Linux drivers to interface with Sage.
In that case, I would run windows in an unRAID vm and host the HDPVR2 there...
I have not tried it yet but likely will, but the latest Win 10 with a beta docker now supports running both windows and linux based containers and uses the underlying built in windows or Linux subsystems from what i have read. Server 2016 also has this ability.
Eventually i will try this out and report back if someone doesn't beat me to it. k
If you wish to see what I am up to and support my efforts visit my Patreon page |
I do this with for my colossus cards. Works great. Windows 2012 R2 running in a VM on the unraid server.
SageTV Server: unRAID Docker v9, S2600CPJ, Norco 24 hot swap bay case, 2x Xeon 2670, 64 GB DDR3, 3x Colossus for DirecTV, HDHR for OTA Living room: nVidia Shield TV, Sage Mini Client, 65" Panasonic VT60 Bedroom: Xiomi Mi Box, Sage Mini Client, 42" Panasonic PZ800u Theater: nVidia Shield TV, mini client, Plex for movies, 120" screen. Mitsubishi HC4000. Denon X4300H. 7.4.4 speaker setup. |
I tried to pass-thru the Colossus and can see it in Windows but the install program does not recognize as a viable card and will not load the drivers. I see the card as: IOMMU group 14 [1745:3000] 02:00.0 Multimedia controller: ViXS Systems, Inc. Device 3000
Retired SageTV in favor of Plex\Emby and YouTubeTV. |
Which version of Windows are you running? I got Sage to recognize the Colossus cards as a source when running Windows 10 but no source found when running Windows Server 2012 R2. Maybe Panteragstk can shed some light on this. |
I had the same issue with another Colossus card I moved to a second PC. I was able to install using an old set of drivers I still had sitting around. (col_drv_30151). Using the same driver I was able to get the Pass-Thru Colossus card to work in an unRAID Windows VM.
So it appear that the current version of the drivers on the Hauppauge web site do not work. (At least with my Card) My problems had nothing to due with passing the card thru to a VM.
Quick question on the MVP | 73cuda | SageTV Media Extender | 11 | 03-23-2008 03:53 PM |
Quick Question | PKTKnight | SageTV Software | 4 | 06-04-2007 11:13 AM |
quick question regarding HD | mbedford | Hardware Support | 1 | 07-19-2006 01:40 AM |
quick question | nissse | SageTV Customizations | 1 | 02-13-2006 02:05 PM |
