Old 03-05-2017, 06:09 PM
willieb willieb is offline
New unRAID/Docker Install questions
Guys,
I had a great day getting an unRAID/Docker test system installed. Couldn't believe how easy it was. But I do have a couple issues/questions.
1. Can I use my InfiniTV 4 with it? I know Ceton released Linux drivers, so I don't know why it wouldn't work, but maybe someone has to do something to get the drivers into Docker?
2. (Related to #1) I have not been able to get OpenDCT going. I tried installing the Crazifuzzy/OpenDCT package but got the following error:
root@localhost:# /usr/local/emhttp/plugins/dynamix.docker.manager/scripts/docker run -d --name="OpenDCT" --net="bridge" -e TZ="America/New_York" -e HOST_OS="unRAID" https://github.com/CraziFuzzy/opendct-docker
/usr/bin/docker: Error parsing reference: "https://github.com/CraziFuzzy/opendct-docker" is not a valid repository/tag.
See '/usr/bin/docker run --help'.
The command failed.
Did I do something wrong? Is this no longer available?
3. I got firewire channel changing working for ONE of my two Fios QIP-7100 boxes. Both worked under Windows -- not sure what changed here. Is anyone aware of a limitation to only ONE box?
4. Is there a way to have the array and SageTV docker start automatically when the computer boots?
Any help you could provide would be much appreciated. Thanks. This has been fun.
Old 03-05-2017, 06:43 PM
For #1 I would ask CHBMB on the unRAID forums if the InfiniTV4 drivers are in one of the versions in the DVB plugin.
For #4: Yes to auto start the array go to Setting tab/Disk settings and choose "Yes" for auto start. For the SageTV Docker go to the Docker tab and look to the right side under the column "AutoStart" and change it to ON for the SageTV Docker.
Old 03-05-2017, 08:18 PM
Thanks. I will check with CHBMB and will change the settings as you suggest for auto start. Hopefully once I get things up and stable I'll have more memory available to Sage for my multiple extenders (and so I can use fanart etc.).
Old 03-05-2017, 08:33 PM
I've got 5GB allocated to one of mine but I've only gotten to about 1.25GB used and it is usually running around 300-400MBs if I remember correctly.
Old 03-05-2017, 08:39 PM
dstanley's Avatar
dstanley dstanley is offline
Guys,
I have four Atlantic Scientific boxes changing channels by firewire. Added one at a time, configuring the tuner (HDPVR) and tuner before adding the next one.
Need shut down the docker, plug in and turn on the next firewire box and then start the docker.
Did you install the UnRaid DVB package (LibreELEC) for your version of Unraid?
So for me - it just worked - good luck!
Old 03-05-2017, 09:26 PM
Thanks. I'll try re-adding one at a time.
Old 03-19-2017, 02:07 PM
Just to report back. I got both boxes tuning by Firewire. All I did was swap the ports my two firewire cables were plugged into. I am sure that did something behind the scenes to "re-recognize" the boxes. After that, they both appeared in Sage and I selected them and they tune. They also tune way faster that I ever got using Windows.
How to setup a USB-UIRT in unRAID/Docker wayner SageTV for unRAID/Docker 42 07-02-2018 09:30 PM
Docker Image for unRaid ChaOConnor SageTV Linux 73 05-28-2017 11:57 AM
Unraid 6.3.1 Docker Update Error dgeezer SageTV for unRAID/Docker 3 02-16-2017 10:17 AM
Is unRAID/Docker the right OS for me? wayner SageTV for unRAID/Docker 32 01-12-2017 03:08 PM
SageTV Docker/unRAID now has a sub-forum stuckless SageTV for unRAID/Docker 0 10-10-2016 07:20 AM
