SageTV EPG Service Discussion related to the SageTV EPG Service used within SageTV. Questions about service area coverage, channel lineups, EPG listings, XMLTV, or anything else related to the service or programming guide data for SageTV should be posted here. |
OTA and Cable on same machine
Hi everyone, I am trying to get both OTA and Cable epg data to show up in the guide.
I am currently running the latest ver 9 on a win7sp1 machine with a amd processor, and 8gigs of memory. Using schedules direct with two lineups. Ceton Infinitv 6, hdhomerun dual and hdhomerun connect for tuners. Whats happening is that I see all the shows in the video resource for both my HDhomerun and my Ceton but the guide does not show the ota channels for the same channels that are in the cable lineup. Example: OTA 47.1 WJAX-HD Cable 433 WJAXDT I can see 433 but 47.1 does not show. Any help would be greatly appreciated.
SageTV Server 7.1.x Win7 64bit SP1, AMD Phenom II x6 1100T, nVidia GeForce GT 520, 16GB DDR3 Asus m5a97 EVO, (2) HD300, SageTV server and SageTV server as a extender, 1 Sagetv Client on a SYX ion. |
If you say remove channel 433 from your lineup channel 47.1 will appear in the EPG. Then if you add 433 back it won't show up in the EPG, but 47.1 will still be there.
Home Network: https://karylstein.com/technology.html |
ota and cable epg
Thanks for your reply KarylFStein,
So there is no way to record on both those channels at the same time?? I'm trying to test how reliable my ota is before shutting down the cable.
How about setting up some recordings for the middle of the night and just pull the plug on the ceton before everyone goes to bed? Just an idea. I try to do all my testing early in the morning before the family gets up....
I don't know of a way to record the same show of different tuners. Do you have a spare computer you could put SageTV on and connect to the OTA device?
Sorry for the late reply. I do have a machine that I can use, but wanted to keep it on one machine.. Thanks all for help I will just use two different machines.
There is one option, if that station is listed twice, for example once as HD and once as SD, you could map the SD guide channel to the HD physical channel. Then Sage would see it as two separate channels and not combine them. Then you'd be able to record both at the same time.
Can I capture on a low-power machine but encode on a more powerful machine? | sofakng | SageTV Software | 2 | 03-01-2011 08:44 PM |
Move v6 files from old machine to new v7 machine | drmargarit | SageTV Beta Test Software | 3 | 06-08-2010 03:52 PM |
How To Find a Time Warner Cable Firewire-capable Cable Box | Brent | Hardware Support | 21 | 11-19-2009 11:40 AM |
Cable amplifier: affect telephone via cable & suggested layout? | Opus4 | Hardware Support | 29 | 05-07-2008 09:55 PM |
~AndyS ~Controlling Digital Cable Box w/ Serial Cable | ccerj8 | Hardware Support | 0 | 06-06-2004 05:16 PM |
