Sagetv v7 to V9 upgrade problem
This is a windows installation. i was running v7 and Because of the EPG from sage being turned off. I decided to upgrade from 7 to 9. i ran the windows installer and it looked like to worked fine. but i did a search and saw where i needed to delete lucene-*.jar. i found a file called lucene-core-3.6.0.jar and moved it out of the jar folder. then tried to start sage and i got a java error and it wouldn't start. I put the file back and restarted sage and it is back sitting with the "object backup database initializing" message. I saw where the fist time sage is started it can take a while to load. How long should i wait and what can i try next.
thanks Brian Olive |
Stop sagetv then rerun the Installer and choose repair
I stoped the SageTV 32bit in task manager. and rerun the installer using repair. I then tried to restart sage tv. It has been sitting on the splash screen Object database backup initializing for and hour. What should i try next?
If it seems to be hanging on the splash screen, I would take a look in the sage log. It should say whether it is actively doing something or if it is stuck (and give a clue about why).
log files
i found 4 log files. Are these we ones you need?
Anyone have any ideas? Should I just wipe the instalation and start from scratch. I hate to loss everything but its been down for three days.
Thanks to anyone who can help |
Uninstall Java through add/remove then run a repair.
The SageTV_0.txt shows that it's trying to access wiz.bin at
"C:\Program Files\SageTV\SageTV" even though all other mentiosn of SageTV seem to referamce "C:\Program Files (x86)\SageTV\" I guess its failing as the folder and file dont exist... Personally, I'd close SageTV and open "C:\Program Files (x86)\SageTV\Sage.properties" in notepad. Then find the lines at the bottom starting "wizard/db_file" and "wizard/db_backup_file" and change them to Code:
wizard/db_backup_file=C\:\\Program Files (x86)\\SageTV\\SageTV\\Wiz.bak wizard/db_file=C\:\\Program Files (x86)\\SageTV\\SageTV\\Wiz.bin
SageTV Server : Akasa Inifiiti Case, Gigabyte GA-P35C-DS3 MB, 8600GT, Core2 Duo (E6850 3GHz), 4GB RAM, ~6TB Filestore , Nova-TD500, TBS 6280, SageTV 7.1.9 New Client 2 :MSI P67A-GD53, i5 2500K Quad core (3.3GHz), 12GB, Windows 10 Pro (and test SageTV 9 Install) Sage Client 1 : HD300, Logitech Harmony One |
This guy seemed to have the same issue with the upgrade not matching the original install path:
https://forums.sagetv.com/forums/sho...73&postcount=5 |
Thank you i will try this.
pjwerdna the path change worked thank you for the help.
Upgrade SageTV V6 to V9 - my upgrade guide | graywolf | SageTV Github Development | 8 | 06-17-2017 08:46 AM |
upgrade problem | wjohn | SageTV Software | 0 | 11-21-2010 05:27 PM |
Problem after upgrade | joejoeyjojo | SageTV Beta Test Software | 1 | 10-08-2010 03:55 PM |
BMT upgrade problem | stlbearboy | Batch Metadata Tools | 9 | 06-26-2010 04:27 PM |
Upgrade from 6.1.9 to 6.2.10 problem. | JParedis | SageTV Software | 3 | 10-03-2007 12:11 PM |
