2nd Dish 211K tuner no longer receives IR codes from USB-UIRT
Sometime around the beginning of April my second Dish VIP211K tuner quit receiving IR codes from sagetv via USB-UIRT. So if Dish VIP211K tuner one is tied up abd SageTV goes to use tuner two will just pull up the the Dish "Your receiver is currently off" screen.
Additional info on my setup: 1 USB-UIRT 2 Dish ViP211K HD solo tuners 2 HD-PVRs 1 HD Homerun Duo 2x OTA ATSC tuners SageTV 9.1.9.778 Java 1.8.0_171 Windows 10 Pro 64, 1803 I cant figure out why it quit working. I did move the computer around that time but all connections were labelled and reconnected exactly as before. VIP211K Tuner one works fine. VIP211k Tuner two and HD-PVR both work fine but the USB-UIRT does not send commands to the tuner to wake it from sleep (select) or to change the channel. It will just start recording with the tuner still sleeping. If I use the VIP211K tuner two remote I can wake it and change channels just fine. I tried removing the HD-PVR #2 and VIP211K two source and re-adding it. I tried uninstalling and reinstalling the USB-UIRT (it did act weird triggering a blue screen a couple of times. Windows seemed unhappy with its driver signing) Anyone have any ideas? I'm stuck. Is there a log file that would give me some clues? I'm curious if the USB-UIRT is sending commands to tuner two. Aside from finding my 20 year old Sony camcorder that can see IR I don't know how to confirm that. Any help would be greatly appreciated. Here is the post I put up in 2012 that shows how to setup the USB-UIRT with two Dish VIP211K tuners using different IR codes. Has worked fine for 6+ years across many versions. https://forums.sagetv.com/forums/showthread.php?t=58018
Server: Win10 Pro 64b 19041.1237, ASUS STRIX X299-E, Intel i9-7940X 14c 28t, 32GB@3200, GTX 1080 Ti Storage: NVMe boot, 2x 4TB HD data, NAS data SageTV: v9.2.5.936 (32b), Java 1.8.0_301 Plugins: Gemstone, Web Interface, Mobile Web Interface, Batch Metadata Tools, Java Heap Monitor Sources: 4x ATSC OTA HDHR5-4US, 2x Sat (Dish), HDPVR(1.7.1.30059.1)<-->VIP211K, USB-UIRT(2.12.26.0 2/24/2017) Extenders: 6xHD300 Other: Homeseer HS3 w/plugins (Zwave, JowiHue, Ecobee, MeiHarmonyHub), Shairport4w, |
A smartphone camera can see IR also.
HTPC: Gigabyte GA-Z170XP-SLI, I7-6700, 16GB, Windows 10 Pro x64, Hauppauge HVR-1600, WinTV-dualHD, Colossus 2, Samsung 850 EVO 120GB, Seagate 3TB, WD 3TB, 3TB, 5TB, Java v1.8.0_231, SageTVx64 v9.2.1.826, Samsung UN60EH6003F, Dish ViP222K, ViewHD 1x2 HDMI Splitter. |
Thanks Denali! Was not aware they could. very useful.
I can confirm it sends IR signals but the Dish receiver does not respond to them. The USB-UIRT lights up in the visible spectrum as well. in my attempt to troubleshoot the driver windows got persnickety with it. Ended up having to use someone elses driver hack to get a somewhat current driver installed. Here it is in case someone else has a similar Code 52 driver issues with USB-UIRT and windows http://usbuirt.com/phpBB3/viewtopic.php?f=1&t=5606 My problem is the same. Tuner one works as it always has. Tuner two does not respond to USB-UIRT commands but works fine with the remote. I'm totally stumped. I ordered another USB-UIRT but I doubt that is the issue. Also, the unsigned driver issues are a pain and I would expect at some point it will just not work since there have been multiple OS versions since the last driver update. Is their another IR blaster alternative that works with sageTV? Ideas: 1. Dish updated the IR codes for their VIP211K tuner = highly unlikely. very old product not hardly used anymore. possible only if it conflicted with their new devices 2. Something changed with SageTV = Unlikely. I don't think its common to have multiple IR configs for a singe IR blaster but I would guess others have similar configs and I don't see anyone else with similar issues. 3. Windows updates = Again, don't see others with similar issues. 4. Corrupt file or config = I have so much time in to my config. It would be so much work to try to start over... What else can I try?
Doesn’t Dish support multiple sets of remote codes by flipping a switch on the back of the remote or something? Is it possible that STB #2 is configured for a different remote than the USBUIRT?
Are you using USB-UIRT zone support or Dishnetwork remote assign address ?.
Resolved
Thank you both for the ideas. I used the the LrnHelper.exe application that you can use to record or send IR remote codes on the USB-UIRT to re-record the #2 tuner for the alternate IR codes again in case they changed or the file had been corrupted or something. Made no difference... So I tried pointing the USB-UIRT more directly at tuner #2 and that did the trick. Little embarrassed. When things got set back up it got mounted maybe 1 or 2 inches higher than before which was just enough to push it completely out of range.
I appreciate the help very much.
Server: Win10 Pro 64b 19041.1237, ASUS STRIX X299-E, Intel i9-7940X 14c 28t, 32GB@3200, GTX 1080 Ti Storage: NVMe boot, 2x 4TB HD data, NAS data SageTV: v9.2.5.936 (32b), Java 1.8.0_301 Plugins: Gemstone, Web Interface, Mobile Web Interface, Batch Metadata Tools, Java Heap Monitor Sources: 4x ATSC OTA HDHR5-4US, 2x Sat (Dish), HDPVR(1.7.1.30059.1)<-->VIP211K, USB-UIRT(2.12.26.0 2/24/2017) Extenders: 6xHD300 Other: Homeseer HS3 w/plugins (Zwave, JowiHue, Ecobee, MeiHarmonyHub), Shairport4w, Last edited by laberet; 07-01-2018 at 10:25 AM. |
HD PVR2
SHS, quick question. Would upgrading my two HD-PVR to HD-PVR2(or other versions) provide any benefits picture quality wise? Stability with my HD-PVRs is good but after a couple months of operation one will lock up. Family has grown use to it but would be great if it was 100%
Dish USB-UIRT IR codes for controlling multiple tuners | laberet | Hardware Support | 0 | 02-11-2012 03:08 PM |
Still having trouble getting USB-UIRT with Dish 211k | rantonow | Hardware Support | 4 | 01-23-2011 03:09 PM |
Problems setting up and using USB-UIRT with toggle codes (Dish VIP211) | popechild | Hardware Support | 2 | 12-14-2008 02:54 PM |
USB-UIRT Dish 211 - extended IR codes | tedson | Hardware Support | 0 | 08-26-2008 01:35 PM |
PVR500 Tuner 2 Receives static - help? | nurowolf | Hardware Support | 9 | 01-18-2006 10:13 PM |
