Drive Enclosure That appears as a LAN Share?
Sounds like a NAS box application, I know - but I don't want a NAS because I already have 6 tb of stuff on two Windiws-firmatted drives and want to avoid the hassle of migration to a NAS' RAID array.
Instead, I would like to simply move those two 3-tb drives from the PC they currently live in to a couple of LAN-present enclosures. The greater agenda being to move my Sage server from my desktop PC to a little fanless OC sitting under my kitchen TV and freeing up the HD-200 currently there for another use. I guess the obvious alternative is a mini or micro OC box with two 3.5" bays and an SD system drive. Googling so far is turning up discontinued devices. Can anybody shed some light?
Server: SageTV 9, Windows 10, i5 NUC Clients: HD200*3 over Cat5e Ethernet + 1 slightly flakey HD 300 + 1 HD200 remote at another residence Plugins: (none yet, looking for recommendations) Storage: NetGear Ultra-6 NAS 10 TB total w/dual redundancy. Plus 5tb QNAP for RecordedTV. Capture: 3 Silicon Dust HomeRun tuner boxes (6 tuners total) Program Source: OTA antenna |
Maybe check out some of the ODROID products from www.hardkernel.com to see if they have something you could use - maybe the ODROID-HC2 : Home Cloud Two would work out.
I use a C2 for my Plex client running OpenPHT and it plays everything that I throw at it will full audio pass thru too.
SERVER: Intel Core i7-3770 CPU @ 3.40GHz - UnRaid Server 6.8.0/DVB LibreELEC with Docker stuckless-sagetv-server-java9 MOTHERBOARD: ASRock-Z77 Extreme4 / 32GB RAM CACHE DRIVE: SSD 1TB ARRAY: 24TB/7 DRIVES PARITY: 8TB EXTERNAL DEVICES: 4x HD-PVR's Firewire Channel Changing TUNERS:NO LONGER RECORDING LIVETV CLIENTS: 2xHD300 2xHD200 SONY ANDROIDTV MINI-CLIENT |
Also check out https://www.addonics.com/products/nas40esu.php
This is a neat device that should work for you - I have an older usb only version that I use. You would need drive enclosure(s) but this is probably the closest you will get to your requirements. You can add the drives without formatting them too.
I pulled the trigger on an Odroid H-2 a couple days ago.
Once I establish that even I can install a distro and get it running, I'll order the second one.
I got an HC2, put an OpenMediaVault system on it, tried migrating a NTFS drive to it, but no luck so far. Re-formatted the drive as EXT4 and OMV was happy, did the share, and all that. But when I included the share in Sage's RecordedTV sources, Sage started throwing errors - which went away when I removed the share... twice.... so I'm pretty sure that Sage was choking on it. Seems contra-intuitive that such a big project as OpenMediaVault cannot support NTFS - so maybe there's still hope there...
I only use my Odroid C2 as a client player- not storage - so all my media is on my UnRaid server.
The Addonics device listed above was probably the better (and easier) choice for what you were trying to do. Hope I didn't mislead you into the HC2. However a quick look at the docs shows that NTFS is one of the file systems supported on a mounted drive!? Dwight
SERVER: Intel Core i7-3770 CPU @ 3.40GHz - UnRaid Server 6.8.0/DVB LibreELEC with Docker stuckless-sagetv-server-java9 MOTHERBOARD: ASRock-Z77 Extreme4 / 32GB RAM CACHE DRIVE: SSD 1TB ARRAY: 24TB/7 DRIVES PARITY: 8TB EXTERNAL DEVICES: 4x HD-PVR's Firewire Channel Changing TUNERS:NO LONGER RECORDING LIVETV CLIENTS: 2xHD300 2xHD200 SONY ANDROIDTV MINI-CLIENT Last edited by dstanley; 01-02-2020 at 05:23 PM. |
[QUOTE=dstanley;623553
The Addonics device listed above was probably the better (and easier) choice for what you were trying to do. [/QUOTE] Yeah, the product description does sound more Plug-and-Playish. But it's sounding more and more to me like the only thing between me and the HC working is User RCI.
Migrating from a single RecordedTV share to that same share plus a local drive? | PeteCress | SageTV Software | 1 | 06-05-2017 03:14 AM |
Mediasonic HF2-SU2S2 Pro Box 4-BAY 3.5IN SATA Drive Enclosure USB2.0 eSATA | viperdiablo | Hardware Support | 0 | 01-14-2010 12:17 PM |
External Hard Drive enclosure durability? | dvd_maniac | Hardware Support | 3 | 08-14-2005 11:33 AM |
Suggestions for DVD drive and external enclosure? | blade | Hardware Support | 1 | 08-11-2005 08:12 AM |
diy hard drive enclosure | IKK | Hardware Support | 2 | 01-31-2005 12:34 PM |
