Old 12-22-2020, 06:59 PM
graywolf's Avatar
graywolf graywolf is offline
Aspect Ration - different default for a particular station?
It looks like my default Aspect Ratio is set to Source which works great for all the channels except one. For some reason that one channel is "stretched" top/bottom. If I manually switch it to Fill, then the AR looks like it should.
Is there any way in Sage for me to say Channel 123 AR = Fill and everything else is Source?
Old 12-22-2020, 07:54 PM
There is a plugin you can install called "Auto Aspect Ratio". You can specify an aspect ratio based on the channel or the program title. You should be able to install it from the plugin manager.
HD300 Default Aspect nyplayer SageTV HD Theater - Media Player 0 12-31-2013 09:41 AM
HD-100 default aspect ratio setting? Skybolt SageTV Media Extender 7 09-12-2009 06:25 PM
Hauppauge 1600 svideo Aspect Ration abbott_m Hardware Support 1 10-22-2008 10:19 PM
MVP DVD aspect ration? Folkboat SageTV Media Extender 2 01-02-2008 01:56 PM
Default aspect ratio vuego SageTV Software 1 01-15-2005 03:28 PM
