Old 01-02-2022, 04:55 PM
Play Togggles OSD no longer works
I have a new unRAID server set up and I am having a strange issue. There is a setting on clients under OSD options that says Play Toggles OSD. That is on but it isn't working. I have tried turning it off and back on and still nada.
Anyone else seen this?
Running SageTV version 9.2.6.1 (64-bit)
Java 11.0.2
OS Linux 5.14.15-Unraid
Old 01-05-2022, 10:21 PM
Can't say i've seen it before, but i've never gone beyond Java 8, so it might be related?
Old 01-06-2022, 04:44 AM
jusjoken jusjoken is offline
I assume you are using gemstone as this is a gemstone added feature.
You may want to post the gemstone logs from after trying the toggle
K
Old 01-06-2022, 07:40 AM
Yes, I am using Gemstone. I didn't know that was a Gemstone only addition, I will check out the logs.
My zip code no longer works for EPG?? alterna SageTV EPG Service 9 05-25-2015 12:56 PM
TVNZ TV One no longer works DylanHall SageTV Australia/New Zealand 27 04-22-2011 05:27 PM
Guide no longer works with MCE remote m1k3g SageMC Custom Interface 3 11-03-2008 06:07 PM
Overlay no longer works...gah cipher SageTV Software 2 08-01-2005 12:16 PM
Mouse no longer works for DVD navigation incoronado SageTV Beta Test Software 0 04-25-2004 08:29 AM
