Old 07-20-2017, 03:08 PM
Beaker's Avatar
Beaker Beaker is offline
List of Default Plugins Please
I'm attempting to track down an Out of Memory error which happens every couple of hours. The error instructs to try increasing Java Heap size (which I have tried - it failed) or that the problem could be caused by a plugin.
I looked through my plugins and found many libraries from previously uninstalled plugins. Since I installed V9 over my V7 install, I can't tell which are installed with V9 and which are digital cruft.
Can anyone point me to a list of plugins installed in a clean v9 setup? Specifically the libraries.
TIA
"Worry does not empty tomorrow of its sorrow; it empties today of its strength." Corrie Ten Boom
Core-i5 6600k
16GB RAM
Hauppauge WinTV-QuadHD
Win10
Old 07-20-2017, 03:36 PM
texneus texneus is offline
Concur, a feature to remove dependancies no longer used when a plug in is removed is needed. It gets to be a huge mess otherwise.
To answer your question, I'm pretty sure NO plug in are installed on a clean setup. The installed plug-ins page was blank on a fresh Sage install.
Old 07-20-2017, 03:48 PM
a 'clean v9' setup has zero plugins (well, the google weather plugin would get installed on first run).
Old 07-20-2017, 04:58 PM
graywolf's Avatar
graywolf graywolf is offline
Been awhile and maybe it was a V7 plugin that may/may not work
but thought there was a plugin to help clean up unneeded dependant plugins
Old 07-20-2017, 04:59 PM
Right now, there's not really a way for sage to know what was installed as a dependent, or what was intentionally installed.
Old 07-20-2017, 05:04 PM
graywolf's Avatar
ok...looked, I was thinking of tmiranda's Remove Plugin and Dependencies (in UI Mod section)
Old 07-20-2017, 08:08 PM
Beaker's Avatar
Thanks, Fuzzy!
Core-i5 6600k
16GB RAM
Win10
Old 07-21-2017, 11:15 AM
tmiranda's Avatar
tmiranda tmiranda is offline
That will only work for installed plugins. I won't clean out JARs that are left orphaned.
java heap, memory error, plugins
List of Plugins for v9 RonBoyd SageTV v9 Customizations 2 07-20-2017 08:32 AM
Default to old style recordings list with SageTV 9 orrd SageTV Software 22 07-19-2017 06:10 AM
Feature wish list for Beta / plugins apschaefer SageTV Beta Test Software 8 04-05-2011 04:08 PM
How do plugins get into the list of plugins? michaeldjcox SageTV v7 Customizations 4 06-12-2010 03:05 AM
List of Plugins in the Plugin Manager Jimmi24 SageTV v7 Customizations 3 05-21-2010 08:03 AM
