Old 05-20-2010, 10:25 PM
[JiF]Mike [JiF]Mike is offline
Question How do I go back to my previous version before v7 beta was released?
I made a copy of my entire SageTV folder before I updated to the v7 beta. Can I simply copy that folder back to revert to my old version? I'd like to try the update again to see if my HD-PVR problems go away. I had a small error when I updated that didn't seem to hurt anything...but now I wonder. I'm going to try it anyway and see...but figured I'd ask while things were copying. Damn that folder got big over the years!
SageTV: Athlon 64 X2 4200+ | 4 GB | 1 Tuner | DirecTV via HD-PVR | Windows Home Server 2011
Clients: PlaceShifter | (3) STP-HD200
Primary TV: Samsung 61" DLP 1080p
Bedrooms: Toshiba 32" LCD 1080p
Customizations: Pheonix | Web Server
www.jiff.net
Old 05-20-2010, 11:01 PM
In case anyone else is wondering this worked. I was able to identify my HD-PVR problem by reverting to the older version. It turned out to be a hardware issue, but I had no way of knowing for sure until I went back and got the same error. I'm back to v7 and all is working.
www.jiff.net
Old 05-20-2010, 11:05 PM
Lucas Lucas is offline
If you are currently on V7,
1 uninstall V7,
2 del Sagetv folder
3 install v6
4 copy back your v6 folder backup
3 x HD300s
Old 05-21-2010, 07:35 AM
sic0048 sic0048 is offline
1 uninstall V7,
2 del Sagetv folder
3 install v6
Just curious, I would have reversed steps 3 and 4 - copy back the v6 folder and then attempt to reinstall. Wouldn't that allow SageTV to reinstall with all the old settings, tuners, history, etc? Am I missing something that makes your steps work better?
SageTV v9 (64bit)
OpenDCT
Using CQC to control it all
How to program Firefly's back button with sagetv's Previous? vorius Hardware Support 26 09-20-2007 09:16 AM
Previous version downloads joel SageTV Software 1 11-24-2006 01:02 AM
need previous version pleeease! jughead SageTV Software 9 07-28-2004 10:57 PM
download previous beta version? waffle SageTV Beta Test Software 2 04-21-2004 04:04 PM
