Old 07-09-2007, 11:50 AM
jblaty jblaty is offline
USB-UIRT + MCE Remote
I bit the bullet and bought a USB-UIRT. I was able to program the IR blaster with my satellite tuner box IR functions, but haven't tested it yet.
I've got Sage setup to look for MCE Remote commands. In fact, my remote is a Logitech Harmony 680, so I can emulate a lot of different remotes. So, I'm only using the MCE remote commands because I'm switching to Sage from MCE2005.
Keep in mind that I've put away the MS MCE USB IR receiver, because I'm using the USB-UIRT for the same function.
I've backed off the operating system to Windows 2000 Professional, because I was having too many problems with XP MCE.
What I'm finding now is that I can't remote control Sage sending the MCE Remote commands to the USB-UIRT. I'm wondering:
1. Is there a way that I can get the MCE Remote to function with the USB-UIRT receiving the IR commands? If not,
2. What remote should I reprogram my 680 remote to emulate to properly control USB-UIRT and SageTV?
I'm quite fed up with all of this stuff, and have spent a considerable amount of money to work around Sage's limitations. I find it interesting that GB-PVR supports the MCE Remote and IR Blaster natively, yet Sage doesn't.
I'm hoping that someone can provide some assistance here before I abandon Sage for something else (hint, hint).
Thanks for suggestions.
Old 07-09-2007, 12:07 PM
You have to teach the remote codes to SageTV when using the USB-UIRT; it doesn't automatically recognize any remote codes via the USB-UIRT. So, go to Detailed Setup -> Commands -> Remote Control Config, then choose the USB-UIRT option. After that, you'll have to link IR codes to the commands you want to use.
Or, continue using the MCE IR receiver for your MCE remote.
Old 07-09-2007, 12:08 PM
Did you learn your MCE remote (or your Harmony with the MCE remote commands) to Sage and the USB-UIRT? Yo have to learn whatever remote you're using to Sage through the Commands menu in the Setup menu.
Old 07-09-2007, 01:52 PM
Thanks! I didn't know that as a newbie, but was able to program the IR commands for the remote. Now I've got another issue, which I'll post as a separate thread (PlaybackException).
New MCE Remote Software StephaneM Hardware Support 298 11-23-2009 06:13 PM
MCE remote transmitting keypresses twice arnabbiswas Hardware Support 1 02-22-2007 10:55 AM
MCE Remote not work fully with Placeshifter devinteske SageTV Placeshifter 5 02-08-2007 11:45 PM
Strange behavior from MCE remote. blade Hardware Support 4 12-13-2006 10:14 AM
Problem getting the MCE Remote Green Button to work bitbyte Hardware Support 10 05-09-2006 03:59 PM
