Old 12-24-2008, 09:56 AM
Ralphjb Ralphjb is offline
Problem Playing back "live" video from R5000, Dish recordings
I believe this problem actual began when I installed the new HD200, but not sure. I did download and install latest beta on both server and the extender.
When I select to watch something from the "program guide" that will be recorded on the R5000, SageTV shows "No Signal". When I check the R5000, it is recording. I know there is a setting either in the registry or in sage.properties for live playback, but can't find that post to try that.
The problem occurs no matter where I attempt to watch live programming - on the Sage Server, on the HD200 or even with a PC and Placeshifter.
Old 01-07-2009, 07:50 PM
MarkV MarkV is offline
Did you resolve this issue? I have always had this problem from the start - R5000 for DirecTV. I did try support a while, but failed to follow-up with them
My recording is done by the R5000 attached to a remote host. The server does not necessarily see the directory of the remote host where the files are stored. Is this an issue ?
Webscheduler recordings - playing back in SageTV ero SageTV Software 2 03-27-2008 07:23 AM
SageTV V6.3.10 Release Candidate Narflex SageTV Beta Test Software 0 02-28-2008 06:07 PM
Odd video stuttering problem Axeman SageTV Software 5 02-22-2007 06:06 PM
