Old 02-09-2010, 04:18 PM
DylanHall DylanHall is offline
Prevent sage server from mounting external disks
I'm running the sagetv server on ubuntu 9.10 and I've noticed a very annoying behaviour. Everytime I connect an external (USB or eSATA) disk sage mounts the disk under /var/media/external.
Does anyone know how to prevent this behaviour?
There are two situation where this is a nuisance.
1. I have a external disk I do backups too once a week. My scripts mount the disk, do the backups, then unmount the disk. With sage running I end up with the disk mounted twice. When the backup completes I unplug the disk. I'm not sure what affect removing a disk that is still mounted has.
2. When I plug my ipod in to copy files over I rely on the gnome auto mount magic to mount the disk with the correct perms/ownership. With sage running the ipod ends up mounted twice with the gnome auto mount thing getting confused and mounting the ipod with root perms meaning I can't write to it.
Dylan
Old 02-09-2010, 04:21 PM
kbyrd kbyrd is offline
I had this problem too...
http://forums.sagetv.com/forums/showthread.php?t=38657
setting:
notify_on_new_drive=false
fixed it.
Current Server: Sage v7.1.9.1 beta w/ Diamond UI on Ubuntu 11.10 x86_64 | Storage: Linux md's raid10,f2 | Client: HD300 extender | Tuner: HDHomeRun for QAM
Old 02-11-2010, 03:08 AM
Not a lot of luck there
I've got "ui/notify_on_new_drive=false" in the properties file for both of my HD200's.
I've added "ui/notify_on_new_drive=false", then "notify_on_new_drive=false", and finally both to the Sage.properties file (restarting between each attempt).
Sage is still auto-mounting my external disks.
Any ideas what I've overlooked?
I'm using Sage 6.6.2 on Ubuntu 9.10.
Old 02-11-2010, 11:23 AM
MitchSchaft MitchSchaft is offline
Maybe turn off autoplay under gpedit.msc?
Start/run/type gpedit.msc and hit enter
Navigate to Computer Configuration/Admin Templates/System, then enable "turn Off Autoplay" for all drives.
Old 02-11-2010, 02:59 PM
Thanks for the suggestion, but it won't help
gpedit is a Microsoft Windows utility (thanks google, I'd not heard of it before). I'm using the Sage Linux edition which appears to have a built-in auto mounter.
Dylan
Old 02-13-2010, 07:40 AM
In that other post I referenced, the problem turned to be that SageMC needed a fix. Are you using a recent version (a pre-release one, I think) of SageMC?
If you're using the default interface, this doesn't apply.
Old 02-28-2010, 07:07 PM
Using the default interface
I'll drop a message to the official support people and see what they say.
Thanks for you help
Dylan
Old 03-04-2010, 05:43 AM
Response from the SageTV support people:
There's 2 ways you could do this in your Sage.properties file. Just make
sure to close Sage when making the changes.
First; you can edit the property "linux/protected_devices" and give it a
semicolon delimited list of device partition names to not mount (i.e.
sda1;sda2;sda3;sdb1).
Second; you can edit the property "linux/new_dev_scan_wait_period" and set
it to a very high value (its a 64-bit integer, millisecond units) so that
any devices newly added while SageTV is running won't be mounted. But it
would still automount existing USB/eSATA drives at startup.
I chose the first option, using the linux/protected_devices setting and it's working perfectly
Dylan
Prevent Client users from changing settings on Server? eehtpc SageTV Software 2 11-09-2007 09:43 PM
Prevent SageTV from Minimizing when External Prgram is launched? ikarus79m SageTV Software 1 11-18-2006 06:59 AM
How Do I Prevent WinTV2000 From Disabling Sage TV Audio? clevo SageTV Software 2 10-09-2006 03:38 PM
Sage 2.2 afraid of large disks? jhkoenig SageTV Software 5 01-12-2006 07:23 AM
ISO mounting & external DVD players Grey_Goose SageTV Customizations 0 05-14-2005 12:10 PM
