Old 02-12-2011, 12:52 PM
GoAWest's Avatar
GoAWest GoAWest is offline
Kaspersky heuristic "detection" of SageTVTranscoder.exe
This morning Kaspersky Internet Security 20111 fired on "SageTVTranscoder.exe" on one of my SageTV client PCs, claiming it was a virus. The complaint was Heuristic.Win32.generic (i.e. not a virus match but rather "looked like" a virus based on behavior or other patterns). I discount this as a virus (HW firewall + Kaspersky + very little if any Firefox-only surfing from that PC) so I denied the recommended procedure (disinfect & reboot).
Just wanted to report the behavior.
Old 02-12-2011, 01:24 PM
GKusnick's Avatar
GKusnick GKusnick is offline
You probably want to report it to Kaspersky, since they're the ones getting it wrong.
-- Greg
Old 02-12-2011, 07:44 PM
timandjulz timandjulz is offline
I can confirm I am getting the same problem.
Since that is two of us I am going to allow the code to execute.
Old 02-12-2011, 08:09 PM
impro impro is offline
I confirm the same.
It is getting very annoying!!!!!
Every now and then I have to deal with this .
After kaspersky quarantined the file it asked me to restore it and as soon as restore it takes it again.
When will netflix or somebody else start stream live TV so we can stop wasting time on stupid software.
Old 02-12-2011, 09:40 PM
nick_l's Avatar
nick_l nick_l is offline
Here's a crazy idea, get rid of Kaspersky, since they are the ones that keep getting it wrong.
Old 02-12-2011, 09:43 PM
Here is the fact:
out of hundreds of software only sage is being detected.
I got rid of Kaspersky on my server.
Temporarily!
But it will be so much better if TV was in the cloud like netflix.
A lot better solution.
And do not have to deal with cable companies for other then internet.
And Townsend of dollars in hardware and hundreds of hours wasting time with trouble shooting.
Old 02-13-2011, 08:40 AM
graywolf's Avatar
graywolf graywolf is offline
This isn't the first time Kaspersky has mistakenly clobbered Sage. Last time Kaspersky had to send out an update. But that didn't happen until folks let them know.
As said before, the problem is with Kaspersky, not Sage
Old 02-13-2011, 09:03 AM
JetreL's Avatar
JetreL JetreL is offline
I have had virus scanners catch everything from Steam components, to Hex editors, to Sage and everything in between. The fact is it's a heuristic scanner meaning it looks for virus like activities. That's a pretty broad definition and they are going to get it wrong from time to time. Certain there are folders shouldn't be scanned for viruses. Your video folder, Applications that you don't want down time, etc. That's why virus companies give you the option to exclude folders and applications from monitoring.
In the grand scheme if you practice pretty safe computing and think before you click you may not need a virus scanner. But that's not for me to decide for you and it really depends on your skill level.
Google?? Facebook?? MySpace??
-=[If you don't pay for the product, chances are you are the product]=-
Old 02-13-2011, 12:29 PM
GKusnick's Avatar
And it would be great if cities had better mass transit. Meanwhile, if your car's airbag malfunctions, you take it back to the dealer and get it fixed. You don't blame the freeway system for the car maker's screwup.
-- Greg
"Backdrops" "SageTV" "Covers" folders - what's creating them mp328 Sage My Movies 4 09-20-2010 05:31 PM
SageTVTranscoder and Convert: can I force "-acodec copy"? phelme SageTV Software 5 06-19-2010 01:33 PM
"Set defaults" for Series forgets "Keep"/"Auto-delete" setting maxpower SageMC Custom Interface 9 05-14-2008 09:44 PM
"Faulting application wmplayer.exe, version 10.0.0.3802, faulting module mpegmux.ax" mkanet SageTV Beta Test Software 3 10-25-2005 09:43 AM
"Hardcoded Breakpoint" in Sage.exe DrWatson error mikbro SageTV Software 1 09-22-2003 08:02 AM
