Old 10-22-2013, 06:14 AM
perfessor101 perfessor101 is offline
Waiting for SageTV to finish initialization
Hello,
I'm looking for some help ... during SageTV's last server outage I think something corrupted.
I restarted SageTV server during the outtage ... since then I haven't been able to get it past the splash screen message "Waiting for SageTV to finish initialization"
I've restored files from a week before the outtage and I keep getting stuck in the same place.
Hoping someone can help with ideas of how to troubleshoot before I have to do a complete restore or a full reinstall.
Thanks for your time and help,
Bobby
SageTV Server: Windows 7 64Bit, Phenom II X6 1090T, Asus M4A89GTD-PRO/USB3 (AM3), ATI Radeon HD 4290, 2 x KHX1600C9D3/4GX, 4 x HD-PVR2 Gaming, , 4 x 320GB recording drives, 2 x USB-UIRT, SageTV Server Beta
SageTV Client & 2 x HD-300 Extender.
40.8TB unRaid 6.6.5 media server
Old 10-22-2013, 07:13 AM
and the sage.properties file
and here is my sage.properties file ...
Old 10-23-2013, 09:20 AM
sflamm sflamm is offline
ue 10/22 5:00:42.545 [Ministry@165fc6a] NOTICE: Forcibly terminating spawned process due to runaway execution detection!
Tue 10/22 5:00:42.569 [Ministry@165fc6a] FORMATERROR UNABLE TO PARSE FILE TYPE FOR FILE-1: \\storage\recordings\Copper-S02E02-AileenAroon-15296553-0.mpg
Tue 10/22 5:00:42.885 [Ministry@165fc6a] Using internal format detector first...
Tue 10/22 5:00:43.028 [Ministry@165fc6a] AV Format:Ret:-2 Program:0 Duration: Format:AV-INF|f=(0:0:00.000'000.0)
Tue 10/22 5:00:43.028 [Ministry@165fc6a] Not find a valid channelRet:-2 Program:0 Duration: Format:AV-INF|f=
Tue 10/22 5:00:43.029 [Ministry@165fc6a] Now using external format detector...
Tue 10/22 5:00:52.503 [EPG@27456b] ERROR Updating EPG Source Shaw Cablesystems - Vancouver
Tue 10/22 5:00:52.503 [EPG@27456b] ErrorText:expand called on Shaw Cablesystems - Vancouver at Tue 10/22 4:59:52.510 expandedUntil=Tue 10/15 6:10:27.658 scannedUntil=Sat 8/16 23:12:55.807
EPG Expanding Shaw Cablesystems - Vancouver at Tue 10/22 4:59:52.510
Repeated errors in communicating with server :java.net.SocketTimeoutException: connect timed out
Tue 10/22 5:01:17.805 [LibraryImporter@907a06] Starting to scan lib import root: \\storage\recordings
Tue 10/22 5:01:17.826 [LibraryImporter@907a06] Skipping video import dir that's also a recording dir:\\storage\recordings
Tue 10/22 5:01:23.884 [LibraryImporter@907a06] Seeker has finished the library import scan.
Tue 10/22 5:01:41.098 [Seeker@aaf9d9] Enforcing keep at most limits for the files...
Tue 10/22 5:01:43.041 [Ministry@165fc6a] NOTICE: Forcibly terminating spawned process due to runaway execution detection!
Tue 10/22 5:01:43.046 [Ministry@165fc6a] FORMATERROR UNABLE TO PARSE FILE TYPE FOR FILE-1: \\storage\recordings\Defiance-15283020-0.mpg
Tue 10/22 5:01:43.322 [Ministry@165fc6a] Using internal format detector first...
You also have an error reaching EPG server, but that should not prevent the system from coming up...
Old 10-23-2013, 09:24 AM
Nevermind, just checked your properties file and it is correct... that is the output.
Try deleting the two shows: Copper-S02E02-AileenAroon-15296553-0.mpg, Defiance-15283020-0.mpg
Old 10-23-2013, 09:27 AM
Invalid channel...
Have you updated you EPG (add/sub a channel to force a manual update)?
If that doesnt work then redo EPG.
See this thread:
http://forums.sagetv.com/forums/showthread.php?t=60848
Old 10-23-2013, 01:31 PM
I tried refreshing all tuner lineups that didn't help ...
I may have to delete my channel lineups and start over
I've noticed two stations BBC World 36 and channel 84 WXYZCAB that I get through Shaw Cable Digital (checked I get video and audio, stations are still there) is coming up with NO DATA in the EPG listing
I'll redo them friday night ... won't have time until then
SageTV v7.0.18 - Waiting on favorite??? MattHelm SageTV Beta Test Software 1 10-05-2010 09:18 PM
BTV & SageTV - I'm making the switch but want to finish up watching old BTV stuff Savage1701 SageTV Software 5 07-24-2009 10:52 AM
Waiting for SageTV to finish initialization .... tmiranda SageTV Beta Test Software 2 12-18-2008 07:21 AM
Adding STB USB-UIRT: Waiting for Remote '0' Press...Locks SageTV Up geogecko SageTV Beta Test Software 5 03-04-2006 10:13 PM
SageTV delete recorded file after finish recording chopper SageTV Software 11 01-30-2006 11:44 PM
