Old 01-23-2005, 02:37 AM
Tengen Tengen is offline
Couple Issues (sound and interface)
Hi, I just downloaded the SageTV trial and I like it very much so far. I just have two issues that I could not find relevant threads or FAQ entries for after some searching:
1) The sound continues after I exit the program, even if I use the task manager. I've tried switching between the various audio filters to no use. The only way to stop the sound is open another TV tuner program.
2) Changing channels using the 0-9 keys and enter keys does not work. The UI only displays a time and the volume bar, not a channel number, and I suspect this may be related.
Old 01-23-2005, 09:09 AM
are you using digital cable or analogue cable?
and what inputs on the pvr card are being used?
what pvr card are you using?
Old 01-23-2005, 11:12 AM
Are you using a supported tuner card? It kind of sounds like you aren't.
Old 01-23-2005, 01:13 PM
I'm using Digital Cable, input type: TV Tuner.
The card is an ATI TV Wonder (not the All in Wonder).
Old 01-23-2005, 01:18 PM
That card isn't officially supported, it's a "software encoder". That would be why you're having trouble with channels not changing and sound not stopping probably.
Old 01-23-2005, 01:44 PM
Thanks.
