Old 05-21-2003, 06:20 PM
pawn's Avatar
pawn pawn is offline
More regarding redundant recordings on dual tuner setuo
Jeff/Dan/Whoever:
Just in case you thought I was mistaken with my problem regarding both tuners recording the identical show at the same time on two channels, please look at this. I'm not harping on it, just hoping it's an easy fix. Attached is a screenshot from my SageGuide last night (early this morning). Conan OBrien is recorded twice at the same time on channel 11 and 25 (same exact show).
Here is the XMLTV data for both listings:
<programme start="20030521003700 -0400" stop="20030521013600 -0400" channel="11 WGRZ">
<title>Late Night With Conan O'Brien</title>
<desc>Model Tyra Banks; Live performs.</desc>
<category>Talk</category>
<category>Tabloid</category>
<audio>
<stereo>stereo</stereo>
</audio>
<subtitles type="teletext" />
<rating system="VCHIP">
<value>14</value>
</rating>
</programme>
<programme start="20030521003700 -0400" stop="20030521013600 -0400" channel="25 CKVR">
<audio>
</audio>
<value>14</value>
</rating>
</programme>
Every single piece of data, except the channel description is identical. So, how could Sage interpret these as different shows? Unless mlar/Lester's plugin is changing the data somehow.
Anyway, the only bothersome part is how it ties up both tuners and nags me about changing channels during a recording (which happens about 5 times a day, BTW).
FYI: I've reverted back to version 1.2.8 if this is important to know.
Thanks again.
Old 05-21-2003, 07:19 PM
Lester Jacobs Lester Jacobs is offline
Hi pawn,
As far as the plugin, and therefore SageTV is concerned, these are two completely different shows. Here's why:
In order for the plugin to consider two shows to be the same, they must have exactly the same <title> tag, <sub-title> tag and <desc> tag. If any of these tags are missing or not the same then the two shows are considered to be unique. Looking at the data below it is clear that the <sub-title> tag is missing from both shows. Therefore these two shows are unique as far as the plugin is concerned and this is what it tells SageTV.
It would be dangerous for the plugin to assume that two shows with the same <title> and <desc> tags are the same without reference to the <sub-title> tag. There are many shows with <title> and <desc> the same but with different <sub-title>.
Therefore your problem in this case is incomplete data being supplied by xmltv and not the fault of the plugin or SageTV.
Please understand that xmltv listings are inherently unreliable with regard to completeness of data. They are definitely good enough to enable the PVR functionality of SageTV for those outside the service area. But glitches such as what you noticed above can and will happen.
Regards
Lester
Lester Jacobs
Web: http://www.digicasa.com
"The shortest answer is doing."
English Proverb. Collected in: George Herbert, Jacula Prudentum (1651).
Old 05-21-2003, 07:30 PM
pawn's Avatar
I leave it rest then and work on my little utility that I hope will sort out a couple of glitches with the XMLTV data.
In either case, this software is proving to be exactly what's been missing in the HTPC/PVR market...thanks for hooking me up ;^)
