Old 07-12-2007, 07:27 AM
matt91's Avatar
matt91 matt91 is offline
Wiz.bin size changes
I'm not sure this is really a beta issue, but it happended with the beta version, so i'll post it here.
I recently upgraded to the 6.2.4 beta. I had mucho connectivity problems the next day, and decided to roll back to 6.1.8. Having fixed the problems (see here), I decided to upgrade again. (The issues were completely unrelated to the upgrade, just coincidental).
What I noticed is that my wiz.bin was ~ 12Mb when I moved to 6.2.4 the first time, and was still that size when I rolled back. When I upgraded again to 6.2.4, my wiz.bin shrunk to ~6Mb. All my favorites, watched shows, etc appear to be there.
Just curious if this is a normal file maintenance, or if I should be worried about something?
Matt
Old 07-12-2007, 09:27 AM
That seems like it is a bit odd to come from normal maintenance... Do you have imported media & is it still listed?
Are all your tuners and EPG data still listed?
If you had a log from when SageTV was started & wiz.bin shrank, it might say what happened.
Old 07-12-2007, 10:22 AM
matt91's Avatar
That's probably what it was. I forgot (duh) that I had deactivated my import directories during this process.
I'm sure if I add them back in, it'd bump the wiz.bin back up again.
Matt
How important is 64K block size msmith8228 Hardware Support 49 01-09-2010 07:08 AM
Power outage apparently corrupts wiz.bin file. Help! bmcraig SageTV Software 20 01-11-2008 10:30 PM
are we there yet? wiz.bin restore/recover ssixto SageTV Software 1 01-07-2007 01:46 PM
Is there a Wiz.bin cleaner out there? perfessor101 SageTV Software 10 04-18-2006 10:26 AM
Changing Font Size broderp SageTV Software 0 03-06-2006 02:54 PM
