Old 12-31-2018, 04:39 PM
nettech_gt nettech_gt is offline
H2 console???
When I attempted to login into my TRAID web server http://localhost:8082/?locale=en_US it would not connect. After looking through the logs I found that something else was now using port 8082. When I just use localhost:8082 it connects to H2 Console?? After some research I found that there is a jar file "h2-1.2.145" in the Sage TV install folder. I think it might be related to this H2 console... as I can not find any other trace of it on my server. Help! Thanx!
Old 12-31-2018, 06:24 PM
wnjj wnjj is offline
Looks like H2 is some kind of database. This plugin seems to use it. https://forums.sagetv.com/forums/sho...t=49138&page=8
Old 01-02-2019, 12:47 PM
Thanx wnjj! I don't have the slim player plugin installed but I notice the SageTV H2 database plugin is and was enabled. I disabled it. And now the H2 console no longer loads when browsing to the localhost:8082. The SageTV web interface and BMT still still work. This is very strange as I did not install it manually or update any other plugins recently. Anyone know what the SageTV H2 database plugin is needed for besides the slim player plugin? Thanx!
Old 01-02-2019, 12:59 PM
SJQ agent uses it.
Old 01-02-2019, 01:05 PM
graywolf's Avatar
graywolf graywolf is offline
Think SJQ uses H2 database also.
Might check this https://forums.sagetv.com/forums/sho...49&postcount=9 for changing the port H2 uses
Old 01-02-2019, 11:39 PM
Thanx KarylFStein and graywolf! I also don't have the SJQ plugin installed. In fact I have checked the dependencies for all 91 installed plugins and none of them list the Sage H2 Database... As I said before I have disabled the plugin and its no longer causing a conflict with TRAID. However I would like to solve the mystery as to why this plugin seemingly randomly enabled its self...
Debug Logging Console cracklepopflash SageTV Studio 1 04-01-2010 05:13 PM
Disable debug console? dwk SageTV Software 2 07-21-2009 09:49 PM
Sage Broke my WHS Console ewm1205 SageTV Software 3 05-19-2009 02:17 PM
Sage 6.4.8 WHS - Can`t run SageTV.exe on Console scoob101 SageTV Software 7 01-14-2009 12:39 PM
Debugging console info beautye350 SageTV Software 0 06-05-2004 03:02 PM
