Old 01-19-2007, 12:10 PM
HeeZy HeeZy is offline
Encode to an MPEG2 352x240....?
i'm trying to set sagetv to encode at 352x240 as an MPEG-2. i don't care about quality as i don't have much HDD space right now. i can try to make a new encoding quality to VCD with 48Khz audio (ready to author to DVD), but then i can't watch it while i'm recording as MPEG-1 doesn't support pausing or something like that.
so i just want the VCD resolution, but in MPEG-2 so i can watch and pause and do whatever, while its recording. and it is a valid resolution in the DVD Spec.
http://www.videohelp.com/dvd.php#tech
i used this recording quality,
mmc/python2_encoding/M2-352x240-192k=videobitrate\=1520000|outputstreamtype\=10|width\=352|height\=240|audiobitrate\=192|audiosampling\=48000
but then the output video is 352x480, which is also in the DVD spec, but its not 352x240 as i wanted.
so does sagetv support this format of MPEG-2, 352x240?
thanks
Old 01-19-2007, 12:54 PM
dvd_maniac's Avatar
dvd_maniac dvd_maniac is offline
I would just use 352x480 and worry about the bitrate and see if that looks good enough. I had setup a 352x240 mpeg-2 setting when using BTV a LONG time ago and when comparing that with the same bitrate at 352x480 on a 42" HDTV no one in my family could see the difference.
If this doesn't work right, Then:
"I'm going to blow up the Earth!"
Old 01-19-2007, 02:00 PM
thats what i was thinking. i should use 352x480. when encoding a 30 minute show to a VCD, the output is about 310MB, where a 352x480 and the same bitrate is about, 410MB-420MB. i guess i can live with that.
maybe its a hardware issue and not sagetv. i use Wintv-pvr-usb2. i'll see if it supports M2 352x240.....
