Old 12-17-2007, 03:43 AM
sunray sunray is offline
ATI HD 650 USB tuner support?
Does Sage support the ATI HD 650 USB external tuner? I was thinking of buying the VisionTek version but I don't see it listed as a supported tuner.
Old 12-17-2007, 01:32 PM
Jesse's Avatar
Jesse Jesse is offline
Hi,
I have a pair of Theater650pro pci tuners, and while they are not on the supported tuner list they do work.
HTH
Jesse
Server: Asus P5Q-EM DO, Q6600, 8 Gigs ram, WHS 2011, 1 HDHomerun(x2 OTA), 1 HD-PVR, 1 Colossus, V7.1.9 sage, 3.3 TB vid storage.
HD100 X1
HD200 X2
HD300 X1
Old 03-17-2008, 03:55 PM
pioniere pioniere is offline
I have an ATI Theater 650 Pro Combo installed on a Dell Dimension 9200, running Vista. The video works fine, but the sound quality is horrendous. The best description I can come up with is that there is static occurring at certain sound frequencies and not at others. The Dell has Sigma Tel audio installed, which works fine for everything else, including Vista's Windows Media Center.
I wonder if you can suggest any course of action from your own experience with this particular card? Are you running XP or Vista? I am actually planning to downgrade to XP (Vista is a performance pig), and wanted to get Sage instead of buying XP Media Center.
Pre-sale question: ATI 650 USB and Clear QAM HTPCBoy Hardware Support 3 10-16-2007 07:21 PM
ATI 650 Recording issue ptaylor Hardware Support 2 10-24-2006 01:11 AM
3rd VBOX USB HD Tuner = Bad :( jptaz Hardware Support 1 02-11-2006 10:57 PM
