Old 06-28-2017, 03:31 PM
Skip Forward not Working when Remote
I was away on vacation and took my Mi Box with me. I remoted into my SageTV and everything worked great except being able to Skip Forward. You would see the arrow advance on the timeline and then jump back to the original spot. The video/audio stayed constant and did not advance.
I have seen similar behavior when using the PlaceShifter remotely. Is this because of the connection speed? Anything I can tune to fix the issue?
P.S. Skip Forward worked fine with PLEX.
John
Tuner: (2) HDHomeRun Prime
Client: (2) HD300
Client: Mini-Client, ShieldTV
Client: (2) Mini-Client, Fire TV Stick 4K
Old 06-28-2017, 05:37 PM
John
I assume you were using the MiBox as a placeshifter? I've had some issues where sometimes I can't forward in a video. In some cases, if I just restart the stream it will work. Likely a bug in the miniclient video handling.
Old 06-29-2017, 04:47 AM
Correct. I think I tried that once and it did not seem to work.
Other than not being able to forward, using the MiBox and Mini-Client was the best remote experience I have had in a long time.
Client: (2) HD300
Old 06-29-2017, 05:32 AM
I'm not 100% sure why the forward would not work. I do think that in placeshifter mode sagetv is transcoding the file. The skips would be slower, but, they should still work. Likely there is a bug in miniclient player. Unfortunately, I don't do much testing with placeshifter, myself, since, I've never used it
Logitech Harmony 700 remote - reprogram 'Skip Forward'? tvmaster2 Hardware Support 0 02-07-2016 11:35 AM
Skip Forward CRASH jrockow SageTV Software 6 08-24-2015 01:19 PM
Recordings Continually Jump back to Beginning after Skip Forward or Fast Forward Carlton Bale Gemstone for v7 2 10-22-2012 06:15 PM
MKV Skip and Fast Forward benjamintm SageTV Media Extender 10 01-08-2008 09:22 AM
Lock during forward skip Llamas SageTV Beta Test Software 9 03-23-2004 07:31 AM
