Old 10-04-2004, 08:08 AM
rwc rwc is offline
Fast Forward (10sec skip) sometimes freezes sage
Hello,
Sometimes when I fast forward by 10 seconds, my sage suddenly freezes. I'm running the lastest version of sage with windows XP SP2.
I'm using the neilm STV
The problem seems to happen regardless of if I use the mouse or if I use the remote control.
Any ideas what could be causing it or how I can debug it?
THANKS!
rwc
Old 10-04-2004, 06:03 PM
David Lawrance David Lawrance is offline
You're not the only one who would like to know (me, too.)
Old 10-04-2004, 06:29 PM
What audio decoder are you using? I've heard about problems with certain decoders (mostly the one from nvidia, I think) -- try changing that.
Old 10-05-2004, 08:09 AM
rwc rwc is offline
I was using the one that came with the haupaug (Inter-something?)
I switched it to the sonic decoder last night to see if it fixes it...for the hour I was playing with it, it seemed ok...
I am using S/PDIF out...if that matters...
rwc
Old 10-05-2004, 08:27 AM
Watter Watter is offline
I have the same problem. I've been looking for a solution for months. This one glitch that I can 't seem to overcome has me in the market for another PVR product for the first time in years.
-Watter
Old 10-05-2004, 09:41 AM
DFranch's Avatar
DFranch DFranch is offline
I used to have that problem. I can't remember if it was with the NVDVD 2 or sonic decoders. I am using the NVDVD 3 decoder now and it has been very reliable.
SERVER: Gigabyte EP45-UD3R | Intel Core 2 Duo 2.67 Ghz | Geforce 8500GT | 4 Gb Corsair DDR2 1066 |
2 Hauppauge HVR-2250 | Win 7 64-bit | Sage TV 6.6.2 | 1.6TB (4 Drives) |
Client: Sage TV STX-HD100 HD Extender
Old 10-05-2004, 11:35 AM
remmy925's Avatar
remmy925 remmy925 is offline
Send a message via ICQ to remmy925 Send a message via AIM to remmy925 Send a message via Yahoo to remmy925
I have had similar problems with some different codecs. NVDVD 2 was one of them. I suggest trying another or checking the settings you have implimented. A problem I had with the Hauppauge was that I tried the registry hack that I read here on the forums. Turned out it was problematic with my machine and I had to switch to the defaults. Dont know if this will change anything, but maybe you should update the mpeg2 codecs you got from Hauppauge. They provide the latest version on their website.
