Gigabit network realistic speed
So I've been looking at my network trying to benchmark how fast my computers are able to talk to each other, and I'm not sure I'm seeing very good results.
Basic network topology is : Code:
router | 8 port gigabit switch | | | | | | | | ---------8 port gigabit switch | | | | | | | | So in theory a gigabit link can carry data at a rate of 1 billion bits per second, which is 125 million bytes per second, aka 125 MegaBytes / second. I'm not seeing anywhere near 125 MB. Nor do I expect to. However, what I'm seeing is seems to be 20-25 MB/s. That seems awfully low. This is between two XP machines, both with 10/100/1000 NIC's on the motherboard, both connected at 1.0Gbs, doing a memory to memory transfer (takes the disk access time out of the equation). Any ideas? btl.
PHOENIX 3 is here! Server : Linux V9, Clients : Win10 and Nvidia Shield Android Miniclient |
What are you using to measure throughput? I just tested four computers on two different gigabit links with Ixia Qcheck and got the following results:
A -> B: 500 Mbps B -> A: 500 Mbps C -> D: 350-400 Mbps D -> C: 130-150 Mbps I'm not sure what accounts for the asymmetry between C and D; maybe I've got a flaky cable somewhere. Gigabit is more sensitive to cabling issues, so if you're not getting the throughput you expect, that might be something to look at.
-- Greg |
Could be a performance problem with the switch... We've seen some Dlink switches here at work that don't get much faster than that...
What are you using for the mem transfer, and what kind of NICs and switches are you using?
SageTV V7 (WHS), Diamond UI Server: WHS with Xeon X3350, 4GB ECC, ASUS P5BV-C/4L, recording into a 6.6TB Drive pool Tuners: 4 (2x HDHR) Clients: 2x HD300, 1x HD200 Extenders, 1x Placeshifter 2x Roku XD |
If you are not using jumbo frames then you will be limited.
Jumbo frame support seems to be inconsistent among hardware components.
[size=1]-MrD ============= Linux Server 7.1.9 (1)HD300 (1) HD200 (1) HD100 (2) PC Clients Intel Xeon L? 32Gb CetonTV cable card /FIOS |
Couple of things to keep in mind. TCP adds about 20% overhead, so the BEST possible throughput you can expect is ~100MB/s. Now then if you are using SMB(windows file sharing) for the test that adds more overhead. Note that smb can be tuned for better performance.
However none of the above is probably your bottleneck. Your bottleneck is most likely your harddrives. The transfer of a large file will only be as fast as the slowest hard drive in the equation can write. 20-30MB/s is probably not too far off for even a modern drives WRITE speed. Edit sorry I see you are doing a memory to memory transfer. How are you performing this? |
I tested using a small program that basically sends 100 MB of data over the TCP pipe and times how long it takes. You run it on both PC's and it spits out some numbers.
I'm not at home so can't find the exact name of the program. In general, it was taking 4 to 5 seconds to send 100MB - which comes down to 20-25 MB/s. I've got the iXia tool set downloaded and am going to test with it on all my machines when I get a chance. btl.
This is not true. Jumbo Frames are not even part of the spec - the IEEE 802.3 working group has *not* reached a consensus on implementing jumbo frames. on older hardware, frame size could cause problems, but not today - i can max out all of my hard drives on my consumer Dlink DIR 655 router, and can hit roughly 122 MB/s via 2 concurrent speed tests. This is without jumbo frames. Furthermore, the slight increases in data transfer (as you are getting, theoretically, more data and less header in a transfer with jumbo frames) is quite minimal, and you are probably better served in making sure you have quality enet card. that is because jumbo frames are *not* part of the IEEE 802.3 standard, so each maker implements it how they see fit, and abide by no standard.
MacBook Core2Duo 2 ghz nVidia 9400M GPU 46" Sammy HLP4663 720p DLP 2x HDHR, all OTA QNAP TS-809: 12.5 TB for Recordings/Imports/TimeMachine/Music HD200 via 802.11n in Living Room 802.11n client in bedroom |
i would highly recommend using diskwriggler for throughput testing:
http://www.xdt.com.au/Resources/Downloads/ this setting works well for me- $ ./diskwriggler -NTSC -C -t -n 2500 -o /Volumes/Disk-1 change the volume to whatever volume you want to test
Stop watch timing on a 100MB file over gigabit is not really accurate. |
XXL Sage Install | digitalgm | Hardware Support | 106 | 10-24-2009 03:59 AM |
Is wMCP really that sensitive to network speed? | Franc | SageTV Media Extender | 0 | 12-08-2006 05:30 PM |
Sage network Encoder and Sage failure? | nyplayer | SageTV Software | 1 | 09-27-2006 06:47 AM |
achieving gigabit speeds? | steingra | Hardware Support | 19 | 03-22-2006 01:21 PM |
extender mvp stuck | aoehlke | SageTV Media Extender | 72 | 01-18-2006 10:01 AM |
