SageTV Mac Edition Discussion related to the SageTV Media Center for Mac edition. Questions, issues, problems, suggestions, etc. relating to the SageTV Mac edition should be posted here. |
Forcing Sage to use Quicktime
Hey, i am trying to sort out AC3 issues - passthrough works with VLC and Quicktime outside of Sage, but no matter what i do, i cannot seem to get passthrough working through Sage.
Back in 6.4.4, QT was supposed to be enabled for any files it could handle, but it doesnt seem to be working, as every file i play defaults to mplayer (running top via the terminal shows this) http://forums.sagetv.com/forums/show...ight=quicktime Quote:
thanks
MacBook Core2Duo 2 ghz nVidia 9400M GPU 46" Sammy HLP4663 720p DLP 2x HDHR, all OTA QNAP TS-809: 12.5 TB for Recordings/Imports/TimeMachine/Music HD200 via 802.11n in Living Room 802.11n client in bedroom |
well, thanks to support, i got AC3 passthrough working again - instead of adding
extra_mplayer_args=-afm hwac3 to the sage.properties file, i added it to the sageclient.properties. Passthrough works perfectly now, and support said that a simple Audio out spidf/analog setting in Detailed Setup will be added in the next version, making extra_mplayer_args=-afm hwac3 unnecessary! Still no success with getting Quicktime to playback media, though i am a bit less worried about it since i got passthrough working...
Re: AC-3 issues
The '-afm hwac3' argument for mplayer works, but it needs to be in SageClient.properties, not Sage.properties. The final build of 6.5 will have audio output selection re-enabled where you can select Analog or S/PDIF, if you select S/PDIF then this argument will be passed to mplayer. Point being if you set this now remember to remove it when 6.5 is released. Note that this only affects mplayer currently. If you hear "helicopter noise" instead of surround then your audio device does not support AC-3 passthrough, at least according to the CoreAudio drivers. Re: QT playback issue A bug was found in the QT player code that will be fixed in 6.5. It has to do with paths not being converted to URLs properly, spaces or other illegal characters were not being escaped. |
marvelous. i can confirm that adding -afm hwac3 to the sageCLIENT.properties file re-enabled passthrough for me.
i am also fully looking forward to QT support, as i have QT working perfectly for all my various formats. (thanks, mostly, to Perian)
QT should be happier with the latest RC, please give that build a try.
Moving Sage due to complete Upgrade | Cabalsan | SageTV Software | 4 | 06-26-2008 09:41 AM |
My Sage TV 6.3 Problems and Fixes (Long) | tcsubwoofer | SageTV Software | 12 | 05-08-2008 07:35 PM |
After Lockup - Sage Not working | wolfpackmars2 | SageTV Software | 3 | 08-05-2006 10:23 PM |
Sage UI disappears during playback | Keith | SageTV Software | 17 | 03-03-2006 03:31 AM |
How To: In-place recompression of Sage Recordings | nielm | SageTV Customizations | 39 | 02-18-2006 11:32 PM |
