Purchase new HDHR Dual or keep original
I have a failing power supply on my first generation HDHR, and I see that Woot is selling the latest HDHR Dual for $70. Since I use OTA a lot, I wonder if it would be a better idea to get a new HDHR rather than replace my failing power supply.
Looking to get a bit of feedback or opinions on this. |
It's a moot point now, just ordered it.
Ditto! Good sale there, just happened to spot it.
The new HDHR has much better QAM performance than the original.
I certainly hope so. I was able to get one from the yesterday's Woot deal. I have two of the older model HDHR's and I've been dealing with scads of errors during recordings. Most of the time they aren't a problem but on occasion it's so bad that ShowAnalyzer gets stuck and I have to run the file through VideoRedo to get it to work. These are on channels that I get 95% signal strength, 95% signal quality, and 100% symbol quality. Given these stats I've never understood why I get stream errors.
I've been trying to hold out buying new tuners but the $70 deal was too hard to pass up. I hope I get better recordings.
Server: i5 8400, ASUS Prime H370M-Plus/CSM, 16GB RAM, 15TB drive array + 500GB cache, 2 HDHR's, SageTV 9, unRAID 6.6.3 Client 1: HD300 (latest FW), HDMI to an Insignia 65" 1080p LCD and optical SPDIF to a Sony Receiver Client 2: HD200 (latest FW), HDMI to an Insignia NS-LCD42HD-09 1080p LCD |
Ya, I have been getting pixelation and drop outs at 95% as well, even if I put it on the cable line. My avermedia duet is flawless on those channels, so I figured that they would have a newer tuner chip and it could only help the situation by just getting a new one.
Dual analog TV tuner with dual RF connectors recommendations needed | davephan | Hardware Support | 3 | 03-02-2010 11:14 PM |
Issue with HDHR (HDHR works fine) | -=Jeff=- | Hardware Support | 1 | 05-03-2009 10:06 PM |
HAUPPAUGE NOVA-T-500 Dual DVB-T PCI & DVICO Fusion DVB-T Dual Express | IanV | SageTV Linux | 3 | 09-05-2008 02:51 PM |
HD Tuner not being selected (HDHR Dual Tuners not being used during timeslot) | Fastrack | SageTV Beta Test Software | 3 | 03-03-2008 07:02 AM |
Dual pvr-150's dual stb's dual blasters, doable? | wrangellboy | Hardware Support | 6 | 12-20-2005 06:41 PM |
