Go Back   SageTV Community > SageTV Development and Customizations > SageTV v7 Customizations > Gemstone for v7
Gemstone for v7 This forum is for discussing the user-created Gemstone custom interface for SageTV.
Old 10-06-2012, 05:17 PM
jorton jorton is offline
Gemstone 1.0174 - Youtube Update
Youtube Update.
Note: in the options screen on the Main Menu you will see "Gemstone API: 1.017 STVi: 1.0174"
As always, comments/suggestion welcome on the forums and issues to be posted in the Issues log here...
Changes posted here....
Old 10-06-2012, 06:39 PM
Is anyone seeing anything odd with the weather location in Gemstone if you are using Provider "World Weather".
I am now seeing my location "Nanaimo" as "Colvilletown(Nanaimo)"...
Yahoo Weather seems OK.
Just curious if it's a Canadian thing or not.
J
Old 10-06-2012, 07:59 PM
MacDaddy MacDaddy is offline
Switched to world weather. Mine works OK for Houston TX.
Frankentivo: iStar D-380HB, SuperMicro X107-F-O, Xeon 1270v3 CPU, Kingston 8 GB 1600MHz DDRR3L x 4
Tuners: 4 x HDHR OTA, 4 x HDHR3 OTA, 3 x HDHR Prime
UnRAID Pro: 1 x Samsung 500GB Cache, 5 x WD Red 4TB (1 Parity, 4 Data)
Extenders: 2 x HD-200, 1 x HD-300 on Atlona PRO3HD66m
Sage: V9.0.14.567 with OpenDCT on unRaid docker, Gemstone, BMT, Web UI, PlayOn, TiSage
Old 10-06-2012, 08:22 PM
jusjoken jusjoken is offline
Our change should not have affected that. Have you tried removing the location and trying a postal code?
k
Old 10-06-2012, 08:50 PM
Yah I removed the location and then added again. Just odd that I never noticed it before.
J
Gemstone FAQ jusjoken Gemstone for v7 9 05-24-2013 12:57 PM
New Sage update and Gemstone jusjoken Gemstone for v7 5 10-05-2012 01:40 PM
Gemstone questions pjpjpjpj Gemstone for v7 7 09-13-2012 10:14 AM
Gemstone Not compatible wayner Gemstone for v7 2 09-07-2012 09:35 PM
Gemstone 1.0203 jusjoken Gemstone for v7 0 09-07-2012 02:14 PM
