Old 10-24-2015, 09:20 PM
nycjoe's Avatar
nycjoe nycjoe is offline
Sagetv9 Hostpost Error
Finally found some time to try out the OSS version of sagetv, but I'm not having much luck with it. It's hotspotting consistently on a vanilla installation of the latest commit on gh. I'm running it on ubuntu 14.04 and using the tarball version after following the instructions on the sticky post on this forum. It's not %100 clear which version of Java to use - I tried Sun java 8, 7, and 6.
I get the error as soon as I try to set up external tuning for my hdpvr, so before installing any plugins or setting anything up. The hdpvr also isn't even lighting up blue when I select 'component' input in the sources menu (but it does when I cat /dev/video0 > /Dev/null)
You can see the errors at:
http://pastebin.com/MUVw9rFh
{"HW": "NUC",
"CPU": "i7-5557U",
"RAM": "16GB",
"Recordings": "2TB SATA",
"Imports": "2x 4TB USB",
"Clients": ["HD300", "HD200", "SageTVClient"]}
Old 10-25-2015, 07:24 AM
That is interesting. While I use the latest jar on my server, I'm still running 32bit environment. I run a 64bit environment on dev server, but no tuners.
You failure appears to be in the tuning a channel area. And this reminds me that in my server environment I use the gentuner plugin, and I'll need to recompile that for 64bit when I eventually move to 64bit server. Since you are using a clean sagetv install, then everything that you have should already be 64bit.
Old 10-27-2015, 12:43 PM
nycjoe's Avatar
Is anyone successfully using SageTV 9 with an hd-pvr?
{"HW": "NUC",
"CPU": "i7-5557U",
"RAM": "16GB",
Old 10-27-2015, 01:44 PM
Taddeusz Taddeusz is offline
Mine has been working just fine on Windows.
Old 10-28-2015, 11:53 AM
Narflex's Avatar
Narflex Narflex is offline
Sage
I use it on Linux...but I only use the Sage.jar and STV from V9. I never changed out all the native files from the V7 ones since nothing new was really added there that affects my home system.
Jeffrey Kardatzke
Google
Founder of SageTV
HELP Error (-3,0x800070043) and Error (-5,08007000e) Podmodder SageTV Software 7 04-02-2010 05:53 PM
HD-PVR Error -4,0x8007001f Error in Playback Xiphoid Hardware Support 13 02-28-2010 11:56 AM
6.4.5 doesn't install: error 1904 DLL registration error snipeman SageTV Beta Test Software 9 07-11-2008 02:31 PM
Playback Error (-4,0x80040217) SAGE 6 Error dealsdyker SageTV Software 5 01-02-2007 08:02 AM
ERROR: sage.PlaybackException: Error (-4,0x8004022f): Boxpin SageTV Software 3 08-15-2006 08:23 PM
