HD Homerun Prime no longer works
I need some help debugging why Sage can’t see my HD Homerun Prime tuners.
I recently had a power supply crap out on me and my server was down for several weeks. After I replaced the power supply, I couldn’t get the Prime tuners to work. I also have a HDHomerun dual OTA box that works fine with Sage. Both the prime and OTA tuners work fine when using them with the HDHomerun Windows app and they both worked fine before my power supply died. I’ve attached some images of my setup. Any ides what’s going on?
- James M - Capture Devices: HDHomerunXTEND, HDHomerunPrime |
Does the SiliconDust software work with them?
Server: i5-2405S (4 core @ 2.5 GHz), 8GB RAM, NORCO RPC-4220 4U case Tuners: 2 SiliconDust HDHomeRun , 2 Hauppauge HD-PVR Connected to 1 Pace700X and 1 TiVo Series 4 DVD Storage: 24 TB TV Storage: 11 TB (4x1.5TB for recording, 5TB for archive) Clients: 3 SageTV Extenders:5 |
Change your SageTV audio decoder to AC3 Filer or LAV Filter and retest it
Have you tried restarting the SageDCT service?
If the IP address of the Prime tuners has changed while SageDCT is running, DCT may not discover that fact. Restarting DCT will likely resolve this issue. To confirm that DCT is able to talk to the Prime, launch the ConfigureSageDCT application. Select the Test tab. Insure that the Command field contains "VERSION", then click the Send button. Within several seconds you should see a valid response (probably "1"). If DCT is able to communicate with the Prime, but Sage still can't see the tuner, it may be necessary to have DCT regenerate the tuner assignments and re-import them into the sage.properties file, just like you did when DCT was initially installed.
System #1: Win7-64, I7-920, 8 GB mem, 4TB HD. Java-64 1.8.0_141. Sage-64 v9.2.1 ATSC: 2x HDHR-US (1st gen white) tuners. HD-200. System #2: Win7-64, I7-920, 8 GB mem, 4TB HD. Java 1.8.0_131. Sage v9.1.6.747. ClearQAM: 2x HDHR3-US tuners. HD-200. System #3: Win7-64, I7-920, 12 GB mem, 4TB HD. Java-64 1.8.0_141. Sage-64 v9.2.1 ATSC: 2x HVR2250; Spectrum Cable via HDPVR & USB-UIRT. 3x HD-200. |
i don't see the ConfigureSageDCT application anywhere. Only "OpenDCT Properties", "OpenDCT Run as Console", OpenDCT start/stop service".
I think it has to do with the network IP address due to what i see in the logs. What exactly doesn't have an IP address? I stopped the service and ran as console and see this: 11:28:57.532 [WrapperSimpleAppMain] ERROR NetworkPowerEventManger - No network interfaces currently have an IP address. 120 attempts remaining. Checking again in 1 second... 11:28:58.638 [WrapperSimpleAppMain] ERROR NetworkPowerEventManger - No network interfaces currently have an IP address. 119 attempts remaining. Checking again in 1 second...
i fixed the issue. IPV6 was turned off in my network adapter. Didn't know it was needed for OpenDCT. Now the PrimeHD tuners work. I would still like to know where the ConfigureSageDCT application is, though.
James
My bad. Ignore my previous posting.
I didn't see anything in your posts that said whether SageDCT vs OpenDCT was being used, and one of the screen captures led me to (incorrectly) think that you were using SageDCT.
HD Homerun Prime with Cablecard and SageTV | SDeGonge | Hardware Support | 5 | 03-17-2017 12:48 PM |
SageTV V6 crops HD HomeRUn Prime recordings. | brandypuff | SageTV Software | 0 | 04-02-2016 05:22 PM |
Issues with Homerun Prime Network Tuner | jimakrause | SageTV Github Development | 0 | 01-15-2016 06:06 AM |
problems with HDhomerun prime and hd homerun | Ericft | Hardware Support | 0 | 07-18-2013 09:22 AM |
SageDCT and Homerun Prime question | diodeut | Hardware Support | 11 | 09-09-2011 06:03 PM |
