Old 11-28-2005, 11:42 AM
Polypro Polypro is offline
Component Video Question
I've got a Viewsonic N2750W 27" LCD...it runs 1280x720 native. There are two sets of component inputs...one set is marked YCbCr and the other is YPbPr. What is the difference? Which ones should a 6600 be hooked up to?
P
Old 11-28-2005, 11:53 AM
Usually, YCbCr means 480i component, and YPbPr means HD component (eg 'P' for 'P'rogressive). You'll probably want to hook up to the YPbPr input.
Old 11-28-2005, 12:03 PM
Thanks Stanger.
P
Old 10-20-2014, 02:03 PM
krasev's Avatar
krasev krasev is offline
YCbCr - digital signal and
YPbPr - analog counterpart of YCbCr
Intel® Celeron® Quad-Core Processor J1900 @ 1.99 GHz; AsRock Q1900M (Intel(R) Chipset (2013-08-01) Ver.9.4.4.1006 Lithography 22 nm; Bay Trail-M/D SOC (formerly known as ValleyView2); RAM 2x4Gb Kingston 1600MHz PC3-12800 DDR3; SSD 128GB & HDD 2TB; SageTV HD200 (Firmware v.20100909 0); Hauppauge HVR-2250 PCI-E; Hauppauge HD PVR-1212; USB-UIRT; Win7Ultimate SP1; FireFox v.41.0.2; SageTV v.9.0.4.224 (STV v.2015101301); VLC v2.2.1; JRE v.1.8.00_73
Old 10-29-2014, 11:49 AM
mikejaner's Avatar
This is wrong. Both are Color spaces, and the inputs on his TV are both Analog.
http://en.wikipedia.org/wiki/YCbCr
http://en.wikipedia.org/wiki/YPbPr
Mike Janer
SageTV HD300 Extender X2
Old 10-29-2014, 12:03 PM
Taddeusz Taddeusz is offline
Straight from the first paragraph of the YPbPr Wikipedia article:
YPBPR is the analog version of the YCBCR color space; the two are numerically equivalent, but YPBPR is designed for use in analog systems whereas YCBCR is intended for digital video.
Old 10-29-2014, 12:37 PM
mikejaner's Avatar
Correct, these are color spaces for analog type systems like CRT tubes and digital systems like LCD screens, not analog versus digital inputs.
Mike Janer
Old 10-29-2014, 12:54 PM
Not entirely true. HDMI supports both full RGB and YCbCr colorspace signals. I know this for fact as the HD100 output used to be RGB only. The firmware was later changed to support YCbCr if the television reported it as supported. My cheapo HDTV always applies overscan to a YCbCr source with no way to disable it. RGB sources are 1:1 pixel perfect at 1080p.
All this is off topic so I'll stop there.
Old 10-29-2014, 01:12 PM
Well then Wikipedia is wrong (shocker), the term YCbCr predated digital video. If you go back to the days before HD, you would see component outputs labelled "YCbCr". When HD and "Progressive" video came around outputs capable of progressive (vs interlaced 480i) became labeled "YPbPr" (P for Progressive), to distinguish them from the SD only inputs.
OK, wrong is a strong word, YCbCr is also used to describe digital component video, but it's not true that (or not as simple as) "YCbCr is digital, and YPbPr is analog".
Old 10-29-2014, 02:13 PM
mikejaner's Avatar
Right, I am just correcting the perception that any component video connectors carry digital information. They do not. Anything digital happens after the analog signal is recieved.
http://en.wikipedia.org/wiki/Component_video
To build on what you said YCbCr (colorspace) was used by Digital interfaces like SDI and Firewire for some old camcorders, studio switching equipment etc..., but nothing like the connectors we are talking about.
These two sets of connectors just mean that one of them is only capable of the really old Pre-HDTV'ish Progressive Scan 480P type of TV sets some people had.
Mike Janer
Old 10-31-2014, 10:40 AM
Tiki's Avatar
Tiki Tiki is offline
So, why are we stirring up a 9 year old post
,USBUIRT (multi-zone)
Source:
Comcast/Xfinity X1 Cable
HDHR, HVR-2250, HD-PVR
Old 10-31-2014, 02:12 PM
Skirge01's Avatar
Skirge01 Skirge01 is offline
What better time to necro-post and raise from the dead a mummified thread on an undead forum?
Software: SageTV 7
