Old 03-16-2009, 04:21 AM
DMZ DMZ is offline
Question Media copy -all- error (UFD with MP3s)
Hello!
I have a SanDisk cruzer micro (U3 capable) USB memory stick with music on it. A total of 15 MP3 files..
When trying to use the SageTV new drive pop-up, selecting:
"Copy Media from F:\"
I then choose the source dir on F: then my directory for media (music) import...
Then "Copy All Files"
I get a message showing:
The file copy process is done.
Result: Error: Error:java.io.EOFException
Nothing is being copied though. However if I select the files one by one the copy works and the files play fine via the Media Center.
The system is running:
SageTV v6.5.9.204
Java v1.6.0_11
SageTV3.xml
Windows XP
Any clues?
SageTV Media Center won't play MP3s jgourd SageTV Software 2 11-17-2008 05:56 PM
Copy media to function shows all of server directories tawpgk SageTV Placeshifter 2 09-24-2007 09:38 PM
Copy media function still does not show drive letters when import is not root. tawpgk SageTV Placeshifter 0 09-24-2007 05:30 PM
Copy media to library talonmike SageTV Beta Test Software 0 08-27-2007 01:32 PM
copy media to library talonmike SageTV Beta Test Software 3 08-07-2007 05:41 PM
