Old 12-08-2010, 01:39 PM
rfeyer rfeyer is offline
EPG not populating
Hi all,
I live in the Albany NY area and have noted, in the past 4 days, that the EPG of SageTV is not updating correctly. I may have 5% of the guide, not specific to any channels, not specific to any time slots. Have tried re-mapping the channels and tried complete re-scanning of the channels, as suggested on this board in other posts, but no luck.
Any suggestions?
Rainer
Old 12-08-2010, 02:55 PM
Have you checked the entries in this FAQ:
My Program Guide is no longer updating and is missing data for some or all of my channels. How can I get it to start updating again?
Old 12-08-2010, 03:04 PM
Opus4,
I tried the forced portion, did not work, and tried removing the strings (which i was nervous about since I am not sure what it does).
I did not know what was meant by 'change source'. Would that refer to changing the capture card in the Setup menu?
Rainer
Old 12-08-2010, 06:29 PM
Got it! Thanks!
Hi Opus4,
the final suggestion, changing the source, did the trick after everything else failed.
Are there reasons why this happens?
In my case, I remember re-mapping the channels so they would have a different line-up on the guide. The sageTV instructions pdf states that this should not make a difference.
Any thoughts?
Thanks again for your help. I had searched and found your tread before, but was reluctant to follow the last step thinking it may get rid of everything I had already configured,
Rainer
Rainer
Old 12-09-2010, 05:54 AM
Remapping channels only affects the EPG for that channel if you remap the station. The station ID has to be correct for the EPG data to be downloaded. So, if a scan didn't automatically match the channel to the correct station, then you would need to remap that.
You would remap the physical channel number to fix a tuning issue.
Otherwise, you would only remap the logical channel number to affect what number is shown for a channel in the Program Guide w/o affecting tuning the channel or getting its listings.
Old 12-09-2010, 06:43 AM
Ericft Ericft is offline
I am having the same issues...some channels have no data, some channels have some shows on the guide but the subsequent hours have no data..deleted my sources, setup cable sources again and still same problem...read FAQ but not sure where it talks about change source? also this was never a problem until yesterday or so??
PS: got it fixed i think with deleting the sources completely and setting them up from scratch...any ideas why this happens?
SageTV Server: Windows 7, Intel Core i5-760 2.8GHz, 7.19 Final, 500Gb System, 2TB + 640Gb recording drive
Rosewill RS-x 4 Esata RAID 5 enclosure 4x1.5tb HDD backup
UNRAID Server Pro: storing dvd and blu-ray rips, music
Extenders: HD300 x2
Tuners: HD Homerun Prime, HD Homerun, HD-PVR, Comcast Cable Box DCH-6200
Old 04-25-2011, 01:26 AM
Synomenon Synomenon is offline
I'm having this problem too.
I've tried deleting sources many times and setting them up again, but most channels still just show "No Data".
Old 05-08-2011, 09:33 AM
lysdexical lysdexical is offline
I'm also having this problem and it started around the same day as this thread began.
EDIT: more info...
I managed to get it to update once by adding a second tuner, selecting the same channel lineup for it (not a copy but selecting the same zip code / provider again) and then removing it a few hours later since I do not actually have anything connected to that tuner. That got the guide to update once, 2 weeks worth I think, which brings me to this past Friday where suddenly I realize all channels say "No Data" again.
Also, according to the system info it thinks it is updating the EPG once per day.
Old 05-09-2011, 03:53 AM
I dumped BeyondTV because SageTV works well and it doesn't have the problems I had been having with BeyondTV. This EPG problem though is a big one and I miss the EPG I had with BeyondTV that just worked.
Old 05-09-2011, 07:04 AM
Have you checked the FAQ entry that I posted near the top of this topic?
EPG data on the web, but not in Sage EPG? Taboo channels? loonsailor SageTV EPG Service 1 07-18-2009 12:05 PM
Populating Tables from Java Functions tpboyce SageTV Studio 3 05-17-2009 05:11 PM
EPG Feature Request - Cloning of EPG lineups Nightrader_ SageTV EPG Service 0 03-18-2008 11:40 PM
EPG server problems; EPG Source Location NO longer exists gwgunter SageTV EPG Service 48 03-20-2007 01:36 PM
loss of func in SageTV in EPG absence?? EPG data for IN, AT, SG? skywalker SageTV EPG Service 5 06-14-2004 07:12 PM
