Old 11-05-2015, 03:35 PM
krasev's Avatar
krasev krasev is offline
ver.9 does not play files named in Cyrillic
problems with Cyrillic... and probably with other languages...
SageTV Version 9 does not play files named in Cyrillic, when I rename them in not Cyrillic letters they play just fine. However version 7 plays any files named in Cyrillic with no problem...
then as long I started talking about languages... in ver.7 Youtube plugin does not show Cyrillic names in the video lists, but previous channel lists are OK... in ver.9 however everything is fine with Youtube but as I mentioned it does not play files named in Cyrillic...
maybe I have to change some settings in properties files? so far I have only these settings:
________________________________________________________________
allow_unicode_characters_in_generated_filenames=true
id3_default_text_encoding=
ui/dump_font_cache=true
ui/load_complete_glyph_maps=true
ui/use_texture_maps_for_3d_text=true
ui/extra_characters_for_glyph_maps=\u00D0\u00B0\u00D0\u00B1\u00D0\u00B2\u00D0\u00B3\u00D0\u00B4\u00D0\u00B5\u00D1\u0091\u00D0\u00B6\u00D0\u00B7\u00D0\u00B8\u00D0\u00B9\u00D0\u00BA\u00D0\u00BB\u00D0\u00BC\u00D0\u00BD\u00D0\u00BE\u00D0\u00BF\u00D1\u0080\u00D1\u0081\u00D1\u0082\u00D1\u0083\u00D1\u0084\u00D1\u0085\u00D1\u0086\u00D1\u0087\u00D1\u0088\u00D1\u0089\u00D1\u008A\u00D1\u008B\u00D1\u008C\u00D1\u008D\u00D1\u008E\u00D1\u008F\u00D0\u0090\u00D0\u0091\u00D0\u0092\u00D0\u0093\u00D0\u0094\u00D0-\u00D0\u0081\u00D0\u0096\u00D0\u0097\u00D0\u0098\u00D0\u0099\u00D0\u009A\u00D0\u009B\u00D0\u009C\u00D0\u009D\u00D0\u009E\u00D0\u009F\u00D0\u00A0\u00D0\u00A1\u00D0\u00A2\u00D0\u00A3\u00D0\u00A4\u00D0\u00A5\u00D0\u00A6\u00D0\u00A7\u00D0\u00A8\u00D0\u00A9\u00D0\u00AA\u00D0\u00AB\u00D0\u00AC\u00D0\u00AD\u00D0\u00AE\u00D0\u00AF
Intel® Celeron® Quad-Core Processor J1900 @ 1.99 GHz; AsRock Q1900M (Intel(R) Chipset (2013-08-01) Ver.9.4.4.1006 Lithography 22 nm; Bay Trail-M/D SOC (formerly known as ValleyView2); RAM 2x4Gb Kingston 1600MHz PC3-12800 DDR3; SSD 128GB & HDD 2TB; SageTV HD200 (Firmware v.20100909 0); Hauppauge HVR-2250 PCI-E; Hauppauge HD PVR-1212; USB-UIRT; Win7Ultimate SP1; FireFox v.41.0.2; SageTV v.9.0.4.224 (STV v.2015101301); VLC v2.2.1; JRE v.1.8.00_73
Old 11-06-2015, 12:42 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
None of those settings should matter. Can you post a log file from when it works in V7 and then also another one from when it doesn't work in V9? That should probably give me enough info to fix it....bonus points for adding a zip file that contains a filename with cyrillic characters in it so it can be reproduced easily.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 11-14-2015, 10:58 PM
krasev's Avatar
Post Log files SageTV7 and SageTV9
Log files SageTV7 and SageTV9 playing files with names in English and in Cyrillic
I played MP4 file named in Cyrillic "ТриПлюсДва-1963.mp4"
first on computer, then on extender (SageTV HD200).
SageTV7 played file on computer and on extender without any problem
sagetv7.zip has SageTV7 log + Sage.properties + extender client properties file
SageTV9 played file on computer without any problem, but on extender it could not play, after renaming file from Cyrillic "ТриПлюсДва-1963.mp4" to English "ThreePlusTwo-1963.mp4" it played just fine as well.
Well mostly I use SageTV from my extender for big screen TV and on extender SageTV9 does not play files in Cyrillic.
sagetv9.zip has SageTV9 log + Sage.properties + extender client properties file
ТриПлюсДва-1963.zip - 5 seconds movie named in Cyrillic I played
Thank you very much for Your consideration
Old 11-17-2015, 03:41 PM
Narflex's Avatar
Sage
OK, I saw a code change that I have no idea why I made it that would totally explain this. I've checked the change into GitHub (I didn't test it because it seemed pretty clear this would cause the problem). Let me know the results after you try out a new build.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 11-19-2015, 03:24 PM
krasev's Avatar
Smile Great
but where can I get the new build to try? so far I can see only 9.03.170 at this location http://forums.sagetv.com/forums/showthread.php?t=62422
and with this build I can not play files named in Cyrillic on my extender HD200...
Old 11-19-2015, 05:30 PM
You can either build it yourself.... Or, you need to wait for me, or someone else to build it and post it I haven't done a build in a while, but I can try to do one tonight or tomorrow.
Old 11-20-2015, 12:18 AM
krasev's Avatar
Smile Спасибо
Thank you very much
Old 11-20-2015, 05:59 AM
Thank you very much
I've uploaded a new build with all the latest changes (as of last night)
https://bintray.com/opensagetv/saget...getv/9.0.3.173
Old 11-24-2015, 02:43 PM
krasev's Avatar
Thumbs up Everything works in stand alone SageTV !
Everything works ! SageTV9 plays files named in Cyrillic on the extender HD200 and on the computer without any problem... this problem is solved
There is a good news... now SageTV9 shows all names in Cyrillic in Youtube, previous build didn't show Cyrillic names there were just empty rows... and Youtube 2015 start working... earlier it was impossible to play anything... problems with download and names in Cyrillic... now everything looks just fine
Old 11-27-2015, 01:56 PM
krasev's Avatar
Exclamation One problem left
SageTV in stand alone mode plays everything just fine. However SageTV in server mode has problem playing files named in Cyrllic on a computer, but it has no problem playing files in extender.
I checked both ways: I deleted "SageClient.properties" file and I duplicated "SageClient.properties" file from "Sage.properties" and in both ways I could not play files named in Cyrillic on a computer, but I could play the same files on extender with no problems.
Old 11-28-2015, 05:48 AM
krasev's Avatar
Unhappy Impossible to search in Cyrillic in Youtube
Search in Youtube in Cyrillic does not give any results or gives some garbage.
any possibility to remove from the menu next choices:
___________
Best of Youtube
Browse Featured Channels
Most Popular Videos
Browse All Categories
Browse Most Popular Video by Category
___________
or move them at the end of the list and to put first:
___________
Search for Videos by Keyword
Search for Channels by Keyword
___________
Old 11-28-2015, 06:29 AM
I honestly don't know Maybe Jeff will have some thoughts on this.
___________
Best of Youtube
Most Popular Videos
___________
___________
___________
Is this part of the Youtube Plugin? If so, you might want to ask in the Youtube plugin thread.
Old 11-30-2015, 02:09 PM
Narflex's Avatar
Sage
Can you post the client & server logs from when you try to do playback and it fails? (and set "media_server_debug=true" in the Sage.properties file on the server before you do this)
Jeffrey Kardatzke
Google
Founder of SageTV
Old 12-03-2015, 12:42 PM
krasev's Avatar
Logs
C:\Data\SageTV\SageTV\sagetv_0.txt
C:\Data\SageTV\SageTV\sagetvclient_0.txt
debug_logging=TRUE
media_server/transcode_debug=false
Server started, then SageTV.exe, played on computer the same file named in Cyrilic "ТриПлюсДва-1963.mp4"
in server log (I guess it's sagetv_0.txt) the name's introduced as "??????????-1963.mp4", but in client log (sagetvclient_0.txt) the name's introduced right way in Cyrillic "ТриПлюсДва-1963.mp4"
without starting server it plays without any problem on computer and extender... it plays any file named in Cyrillic on extender HD200 without problem as well
Old 12-04-2015, 01:04 PM
Narflex's Avatar
Sage
There must be something in your client config where you're forcing it to use MPlayer for playback rather than DirectShow. We apparently never added Unicode filename support for playback in MPlayer, and that's why it's failing.
I think the setting you have wrong is that you have:
always_use_dshow_player=false
set on your client and it defaults to true...so change it back to true.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 12-05-2015, 09:47 PM
krasev's Avatar
Thumbs up Thank you. It plays everywhere...
after changing line
from "false" to "true"
it plays any file named in Cyrillic everywhere now... in extender, in computer with and without server running... Thank you
maybe any idea with Youtube 2015? I wrote in their branch about it that impossible to make any search in Cyrillic and so far no answer...
there is no any results if you search in Cyrillic... none...
Looking for hardware to stream Netflix and play files from the LAN files davephan The SageTV Community 5 12-08-2011 04:25 PM
Two feature requests: Cyrillic in on-screen keyboard and side panels color scanner95 SageTV Beta Test Software 0 06-17-2011 04:03 AM
Fixing an incorrectly named .jar tmiranda SageTV Studio 7 03-02-2011 07:41 PM
Channels named incorrectly werxie SageTV United Kingdom 1 11-10-2008 02:01 AM
SageTV with English User Interface to recognize media files written in cyrillic? krasev SageTV Software 9 09-11-2006 07:29 PM
