How do I add OTA HDTV Channels
I have a few local OTA HDTV channels I want to add to sage tv but I can't figure out how to get it to work without NO SIGNAL popping up.
I have a fussion HDTV 5 lite card, the FussionHDTV program shows all the channels I have local fine with decent signal strenghts. An example of what Fussion shows is: CH D8-1 SERVICE FOX8HD TYPE 8VSB RF 29 Okay, so in sage, I go to video source setup and click add channel to lineup. It asks for the name of the channel, for a digital channel, dont forget that you may need to add the DT.... Okay, so looks like this field should be FOX8HD so that is what I type. Now it asks for the new channel number for FOX8HD, what do I put there? Next it asks for the station id for FOX8HD, what do I put there? Can anyone help? Thanks! |
The manual (pg. 159) details how to accomplish what you want.
I have the same card as you, and where I live, I can pick up both Miami & West Palm Beach stations (to the North and South of me). The default epg can use either location, not both. Adding channels is easy. But finding out what the channel ids are for the new channels for guide data, requires some work (that I wish I didn't have to do). |
I was able to add that channel successfully but station id is giving me problems. The only station id I see is in the properties file which shows you the last station id you visited so I tried using id of the non-hd station which maches the HD station I am adding but get an error message that it already is used.
Really not sure where to go from here, can any one give a hint how to figure out station IDs? |
To find station IDs, see this post. Also read posts after that one for some further info.
Is FOX8HD really the channel name? See what Zap2It lists as the name -- I thought there would be a DT after it, such as WXXXDT or KXXXDT, depending on what part of the US you are in (unless you aren't in the US). - Andy
Sweet, thanks for the info Opus. Yes, according to the FusionHDTV tuner program scan results, it is FOX8HD and there are others HD ones without DT or HD at the end, for example the ABC HD channel is listed as just ABC. Some are like that because of Katrina I believe, 3 stations lost their antennas and piggy back over a local PBS station.
Sorry, but one more quesiton. Some of my local HD channels aren't listed on zap2it, but the non-HD ones are. When I choose the Station ID for the non-HD one it gives me an error that it is already in use. Any way to force it to use that station ID so I can get the program info for my HD one?
I don't believe you can have 2 channels with the same station ID, which is why the STV doesn't allow that assignment.
