Old 03-04-2011, 07:44 PM
dstanley's Avatar
dstanley dstanley is offline
Diamond Fanart
MyMovies puts fanart in my movie folders named "mymovies-front.jpg" - any chance of getting a Diamond Fanart option that would use that image?
Old 03-04-2011, 08:36 PM
PLUCKYHD PLUCKYHD is offline
Look for the property on your server that list all of them and you can add it
Or you can manually change the property set and it will work on restart. Make sure you have the service is stopped when you edit it. Sorry not at computer to give you property names but starts with jorton and should be easy to find.
Old 03-04-2011, 09:20 PM
dstanley's Avatar
Found it ... No problem ... Thanks for all your work ... I really appreciate it!
Old 03-04-2011, 09:22 PM
No problem be sure to clear the cache
Old 03-07-2011, 05:49 PM
Blimpo Blimpo is offline
Plucky I must be blind I dont see the .properties file your talking about.
Could you give me a directory path to look in??
or is it a configuration in the Phoenix Core Services.
My Bad I found it -- Under Detailed SetUp --> Diamond FanArt --> Diamond Fanart Options
Use Folder Posters First --> On (Default is off)
Use Folder Backgrounds First --> On (Default if Off)
Then in the menu selection Example Video --> Diamond Wall --> Diamond options
Show info ... On (default is off)
These are the setting I Changed
Now I can See the Fanart from MyMovies and the DVD covers.
Old 03-20-2011, 04:39 PM
Gunserotti Gunserotti is offline
I have a few follow-up questions. I am trying to use diamond with the mymovies meta data program. In each movie folder mymovies writes the following files:
Hidden files:
The fanart.jpg and folder.jpg files both contain a "fanart" type images. The mymovies-front.jpg file has the movie cover. This is what I want to use for the diamond views.
The problem I'm having is that diamond is using the folder.jpg file for the diamond views. I want to use the mymovies-front.jpg.
In detailed settings--->diamond fanart----there is an option to use folder first and use fanart first. Is the word poster synonymous with "movie cover?" In other words do I need to add an option to use mymovies-front.jpg? If yes, a nice feature would be to include this in the default choices....just to save some remote control typing. Thanks
Old 03-20-2011, 04:48 PM
Manually edit the server property is easier.
Mymovies only supports one fanart backdrop so why are you saving it two different way? Front cover and folder.jpg should be the same. The front-cover is simply a backup. So you really shouldn't need the extra option either.
Old 03-20-2011, 06:35 PM
Ahhhh... I see what I did wrong. In the Mymovies metadata management area I edited the name of the backdrop file to save as "folders.jpg." I did this because I thought it would make it easier to work with Diamond. I also had the "save covers" option as "folders.jpg" checked. So the backdrop was overwriting the folders.jpg file. This is why I was ending up with two versions of the backdrop.
As usual thanks...
Diamond Sub-theme: Diamond MKANET Mod mkanet SageTV v7 Customizations 2 02-21-2011 05:18 AM
BMT / Fanart / Themes Leveraging Fanart? Addict SageTV v7 Customizations 2 09-09-2010 05:38 AM
Fanart: Complete Fanart Collection... 4000 Movies and TV shows mkanet SageTV Customizations 24 04-20-2010 03:31 PM
SageMC, Fanart, MediaScraper & Central FanArt folder structure Ė Help requested rmac321 SageMC Custom Interface 24 06-14-2009 02:00 PM
