Old 08-17-2008, 07:12 AM
harryf harryf is offline
XMLTV importer not closing down after import
Hi,
I am using StephaneM's importer version 3.2 to automatically trigger the grabber and then import the data. The problem is it does not shut down after it has finished, so the PC does not return to standby, also the importer screen is in front of Sage until it is shut down manually. The old version of the importer did not have this problem.
Old 08-17-2008, 07:12 PM
StephaneM's Avatar
StephaneM StephaneM is offline
You should delete and recreate the scheduled task through the Importer GUI because it seems that it was not converted correctly during the 2.x to 3.x upgrade: the Import process has no GUI at all, so you should not see anything on your PC screen during the automated import (only the spinning taskbar notification icon)
Regards,
Stéphane.
Problem with XMLTV import : No Data ranageman SageTV EPG Service 7 04-02-2008 12:07 PM
ADDING CHANNEL TO XMLTV Import Tool rnewman SageTV EPG Service 2 03-09-2007 05:00 PM
LM Gestion XMLTV Importer + lost program guide crollorc SageTV Beta Test Software 7 12-06-2006 09:55 AM
Question about XMLTV Import Tool: categories svalmorri SageTV EPG Service 4 10-05-2006 09:44 AM
Sage fogets about series recordings at xmltv import Madcoder SageTV EPG Service 2 04-07-2006 03:46 PM
