Old 01-21-2008, 11:56 AM
hondaman hondaman is offline
Seriously? I cant play DVD isos?
From what I understand SageTV doesnt support dvd iso natively, and the only plugin that does this is obsolete because it doesnt work with v6
Am I understanding this right?
Old 01-21-2008, 12:21 PM
Khristopher Khristopher is offline
If you mean physically reading an .iso image, you are correct.
If you extract the VIDEO_TS folder to your hard drive however, it will read/play it like an actual DVD.
Old 01-21-2008, 01:27 PM
Actually, it looks like there is some support for this in the HD Extender. http://forums.sagetv.com/forums/show...d+extender+iso
B
Old 01-21-2008, 05:46 PM
If you like, there are a number of virtual optical drive programs that will let you mount that .ISO into a virtual DVD drive. You can then perhaps use the external programs plugin to run the commands to insert the .ISO into the virtual drive, and then play it back via Sage's normal DVD playback method...
Or, just extract the ISO's to folders. The space required is the basically the same, as .ISO's aren't compressed, and sometimes actually take up more space than the individual files, because the ISO keeps a lot of filesystem information in the file as well.
Old 02-04-2008, 12:48 PM
bbkim bbkim is offline
Possible Using the External Apps STVi
This has been my issue. I used the External Apps STVi (http://forums.sagetv.com/forums/down...do=file&id=189) to launch VLC to view iso files, and it works pretty well. No need to mound/unmount iso images. Just modify the property file to recognize iso files.
If this sounds good to you, you might want to change few things in the VLC preference to make it to your likings (i.e. full screen, one instance only, etc.)
SageTV's DVD feature vorius SageTV Software 15 02-05-2007 01:11 PM
Mount and Play DVD Images cornrow SageTV Customizations 28 12-28-2006 06:13 PM
need help getting Sage to play DVD movie.. mattress SageTV Software 16 04-09-2006 02:57 AM
Playing DVD ISOs phenixdragon SageTV Customizations 1 02-25-2006 11:59 AM
