Old 05-16-2012, 12:49 PM
rnadeau's Avatar
rnadeau rnadeau is offline
Can't connect using Dyndns hostname
I have a free dyndns host name that I setup a few years ago because I have a weather station on a server. I can type my host name and reach my weather page, but if I type my hostname http://ronsweather.homeip.net:31099, I can''t connect to my sage server. I can connect through the locator or by typing the wan ip address, but the whole idea of using dnydns is so I can just type the hostname regardless of what the ip address is. Any ideas why I can't connect with my hostname? I do have port 31099 directed to my sage server
Sage Tv Server-Amd 4200FX quad core, Asus Nvidia EN610 Hdmi out , 8 Gig Ram ,(3) HVR-1800, 3.5 terrabyte storage, Windows 8 Pro on sage 9.09 system . Media Server- 6 Terabytes on 5 drives, Amd x2 6000 8 useable gig ram on win 7 32 bit media server.
Old 05-16-2012, 02:27 PM
Use this site to check your ports...
http://www.yougetsignal.com/tools/open-ports/
Also make sure dyndns is set to the correct IP and not the local IP. Login at the dyndns site and look at IP. There are some up-daters that update the wrong IP to DYNDNS.
Old 05-16-2012, 02:57 PM
I just connected to your server via placeshifter. Make sure you use just ronsweather.homeip.net.
B
Old 05-16-2012, 03:36 PM
rnadeau's Avatar
Ok Thanks, I just tried it without the http and port number and it connects.
Use hostname in auto-connect instead of IP? aweber1nj SageTV Beta Test Software 7 05-05-2011 11:23 AM
Dummy's guide to adding netbios hostname to my HD-200 mkanet Hardware Support 1 02-11-2010 11:31 PM
How can I assign a hostname to my MediaMVP? zubblwump SageTV Media Extender 7 01-10-2008 09:42 AM
How to enter "server address" w/my dyndns info? IVB SageTV Placeshifter 15 12-16-2007 06:35 PM
DHCP, Dyndns.org and SageTv Client Connection yeswork SageTV Software 13 12-28-2005 09:37 AM
