Go Back   SageTV Community > SageTV Development and Customizations > SageTV v7 Customizations > Gemstone for v7
Gemstone for v7 This forum is for discussing the user-created Gemstone custom interface for SageTV.
Old 09-25-2012, 04:53 PM
jusjoken jusjoken is offline
Gemstone 1.017 - 4th private release
Note to testers - a new release has been sent out.
****We would like to make this release public by 9/27/2012 if all goes well with this version****
As before, comments/suggestion welcome on the forums and issues to be posted in the Issues log here...
Please re-test any of the issues you have seen previously including those you have raised on the Issues List (check for current issues before posting new ones and add comments on the existing issue if you have the same or similar one).
Changes posted here....
Old 09-25-2012, 05:09 PM
Recent Widgets and UPcoming recordings are only showing episode name. Hard to tell which series is recording. See screen attached Series Bones is recording.
Old 09-25-2012, 05:19 PM
MacDaddy MacDaddy is offline
Thanks again for all your hard work on this. Just had a few minutes to try things out before settling down for TV tonight. Will have time to exercise things a bit more tomorrow. So far, deleted flow seems to work as expected and weather provider change works as expected. Playon is still MIA, but I think that is more on EP's overcommitted plate.
Frankentivo: iStar D-380HB, SuperMicro X107-F-O, Xeon 1270v3 CPU, Kingston 8 GB 1600MHz DDRR3L x 4
Tuners: 4 x HDHR OTA, 4 x HDHR3 OTA, 3 x HDHR Prime
UnRAID Pro: 1 x Samsung 500GB Cache, 5 x WD Red 4TB (1 Parity, 4 Data)
Extenders: 2 x HD-200, 1 x HD-300 on Atlona PRO3HD66m
Sage: V9.0.14.567 with OpenDCT on unRaid docker, Gemstone, BMT, Web UI, PlayOn, TiSage
Old 09-25-2012, 05:54 PM
Turn on the extra info in the widget settings and you should get both the series and episode. If this isn't going to work for everyone we may need some additional settings to customize what is displayed.
k
Old 09-25-2012, 05:59 PM
k
Extra Info only shows the Episodes and the Categories. It works in some of the Upcoming Recordings (see info2 pic) not recent.
Old 09-25-2012, 06:59 PM
I made a number of changes to this part of the code so I will take a peak and get this fixed for the next release.
k
Gemstone 1.016 - 3rd private release jusjoken Gemstone for v7 33 09-25-2012 05:52 AM
Gemstone 1.015 - 2nd private release jusjoken Gemstone for v7 2 09-08-2012 12:30 PM
Gemstone 1.0203 jusjoken Gemstone for v7 0 09-07-2012 02:14 PM
