Go Back   SageTV Community > SageTV Development and Customizations > SageTV v7 Customizations > Gemstone for v7
Gemstone for v7 This forum is for discussing the user-created Gemstone custom interface for SageTV.
Old 02-16-2014, 02:06 PM
Help - I screwed up my Fanart Caching
I am still not sure exactly what I should be using for settings for Fanart cache.
I have been moving some movies around as I added an additional hard drive to my system and some posters were missing. I was able to manually fix them using the CMT plugin but I figured I would rebuild the cache as it doesn't take my manual intervention.
So I just cleared the File System Cache and the Prebuilt the Cache. I have everything set to Yes under precache. But when it is done I am much worse off than before? Less than half of my movies show posters in the wall. Why is that - shouldn't I be back to where I started?
And many of my TV shows that used to have banners no longer do - at first no TV shows had banners, and then a few minutes later a few showed up.
I have deleted both memory and file system caches and I am trying again.
Old 02-16-2014, 04:59 PM
OK, finally after a second reload and a bit of shutting down and turning on most of the fanart came back properly.
One question - is there any way to change a poster and see it reflected immediately? I can change the default poster in BMT or CMT but it doesn't ever get used until you reload the cache, if at all. Is it possible where you could choose to reload the cache for one specific Mediatitle?
Old 02-17-2014, 04:59 PM
jusjoken jusjoken is offline
Sure. Go into Fanart Manager and select a new default or delete unwanted fanart from there. It should work.
k
Fanart Caching wayner Gemstone for v7 2 01-02-2014 02:55 PM
Is there a way to disable fanart disk caching/resizing? mkanet Batch Metadata Tools 26 02-22-2011 08:21 AM
Local caching of fanart. panteragstk Batch Metadata Tools 11 12-16-2010 09:39 AM
Caching of images sciguy Sage My Movies 14 11-21-2010 09:04 AM
Thumbnail caching chiledog SageMC Custom Interface 0 01-29-2009 08:16 AM
