Old 01-08-2017, 01:34 PM
Weirdness for movie providers - htbackdrops coming from nowhere
IN the BMT config I have two providers listed for Movie Metadata Provider(s) - tmdb and imdb. But when I click on Find metadata for a movie and the click on source I get the following options
"themoviedb.org V4 -- (tmdb)",
"htbackdrops.com -- (htbackdrops)" and
"thetvdb.com -- (tvdb)".
Where is it getting htbackdrops from and why is TVDB showing up in movies?
FYI when I switch the search type to TV it gives me the same three options.
Old 01-08-2017, 02:49 PM
BMT simply lists the providers that are installed, in this case 3... tmdb for movies, tvdb for tv, and htbackdrops for music. You just select the one you want based on the type... bmt might auto-select the best initially.
Old 01-08-2017, 02:56 PM
Ok, I didn't know htbackdrop is for music and I didn't see it listed anywhere.
But imdb is in my config, why isn't it an option for sources? And this is on my V9 server. On my V7 server I get several options DVD profiler, IMDB, MyMovies, etc and I still only have imdb and tmdb in the config screen.
Old 01-08-2017, 03:37 PM
The only supported ones are tmdb and tvdb all the rest have been removed. (htbackdrops likely doesn't work either).
WMC Changing guide providers. nyplayer General Discussion 5 07-25-2015 12:12 PM
Phoenix music/music video support: http://www.htbackdrops.com possibly? mkanet Batch Metadata Tools 1 10-19-2010 05:11 PM
adding satellite providers ? JoeNezZ Hardware Support 0 11-19-2008 10:19 AM
EPG does not show as many providers as Zap2it dtshedd SageTV EPG Service 2 01-01-2007 11:13 PM
Movie Listings and Trailers Coming Soon... aperry SageTV Customizations 44 05-07-2006 11:23 PM
