Old 06-23-2005, 01:30 PM
1972's Avatar
1972 1972 is offline
Question No EPG for one channel, how to make small recordings?
Hi all,
I'm using the composite input of my Hauppauge 350 card for an extra channel. (I have connected a Digital TV decoder box to it).
But I have no guide for it. No problem to me, only when I want to record something.
For example, I want to record a show from 20:05-20:55.
What I do is sellect a "No data" block from 20:00-22:00 (all "no data"blocks are 2 hours long) and increase the start and decrease the stop time. Also no real problem for me, but it takes some time since I can only increase/decrease it 1 minute.
So my question: is it possible to make the "no data" blocks smaller, for example 30 minutes long?
(I looked into the properties file, but couldn't find anything....)
My persional PVR: Intel Celeron-D 2.66 GHz, 512 MB, Hauppauge PVR350 (incl. remote control), XFX-5200, 2x160 GB HD, WinXP MCE 2005 (ex-SageTV user)
Old 06-23-2005, 01:56 PM
There should be 2 arrow buttons on each side of the start/stop time adjustment dialog -- for 1 & 15 minute increments.
You should also be able to use Timed Recordings and then set the start & stop times you want. (But the hours & minutes are both changed by 1 there...)
Old 06-23-2005, 02:09 PM
1972's Avatar
Thanks for your reply!
You're right, I know that it is possible with the "default" SageTV.. but I'm using the SageMC STV and it does not have the Timed Recordings function.
Sorry I forgot to mention it
(By the way: I asked mldude about it and he said no one ever asked for that option, so why implement for only me. He's right ;-).
However going back to the "default" SageTV is no option for me, because it doesn't have the extensive way of playing MP3 (genres, etc.). This is a feature of SageMC I really enjoy.
I hoped that the "2 hours" was some kind of setting I could change somewhere...
