Old 01-09-2009, 03:16 PM
zoltran zoltran is offline
"Best" settings for a HDPVR
I have sage working with a HDPVR rev C2. Using the latest Hpg drivers and recording sound over stereo. So far no real issues ..
But I do have a couple of tuning questions.
So ... any help with the following would be appreciated.
1) It takes 10 or more seconds to change channels. During this time the screen will flash the new chanel/then a shot from the prior channel/then settle down.
During this time audio stutters badly. Is there a way to improve this?
Definitely fails the WAF test.
2) Is there a way to have the HDPVR record at different bitrates for HD vs SD channels? ie, Great for HD, and fair/good for SD.. No point running a 3GByte per hour stream for SD tv. ?
Any other 'best practices' / suggestions ?
TIA /// Wes
Server AMD2600/WHS approx 2Terabytes of storage
HD-PVR/Starchoice/Motorola settop box and IR-blaster
Extenders and USB-UIRT enroute ...
Old 01-09-2009, 03:38 PM
I use firewire channel changing & then use this property to cause the HD-PVR to wait 9 seconds before starting to record, so that the channel change doesn't get recorded:
mmc/encoders/<some #>/delay_to_wait_after_tuning=9000
If SageTV detects SD resolution recording, it already lowers the recording quality to save space. (This won't have any effect if the STB is always outputting at HD res.)
Old 01-09-2009, 04:13 PM
Skirge01's Avatar
Skirge01 Skirge01 is offline
Should this line be in the properties file on the server, the client, or both?
Old 01-09-2009, 04:24 PM
That goes in the sage.properties file (server), it controls how long Sage waits before trying to start a recording after issuing the channel change command. The HD PVR is rather sensitive to the stability of the input signal so the delay allows that to stabilize before Sage begins a recording. I set mine to 4000 (4 seconds) and it's been, I think, perfect since.
Might I suggest that be made a default (or at least something > 0) for the HD PVR, if it hasn't already? It seems a lot of HD PVR problems are solved by this.
Which reminds me, I should try my custom max vbr quality now that I've gotten my HD PVR stabilized with this (and newer Sage/drivers than the last time I tried it).
hdpvr hd-pvr whs
Must the HDPVR be directly attached to Sage Server? Ron Hardware Support 8 02-18-2009 04:16 PM
SageMC settings menu suggestions tchapin SageMC Custom Interface 2 11-17-2008 01:03 PM
SageMC series settings questions tchapin SageMC Custom Interface 0 11-08-2008 10:40 AM
Bad HDPVR or some other issue? pat_smith1969 Hardware Support 5 10-20-2008 01:09 PM
I would like to reset all SageTV 4.0 registry settings back to the original defaults mkanet SageTV Software 3 11-14-2005 07:03 PM
