Old 08-11-2009, 09:24 AM
BostonDriver BostonDriver is offline
Actual Start Time vs. Program Guide
Hi,
I don't know what the right terms to use are, so my searches didn't turn up anything. Sorry if this has already been asked, but the FAQ didn't have it.
Does SageTV have the ability to record a program I select, even when it starts at a time which is different than what is shown and selected via Program Guide?
Specifically, if I'm recording a sporting event that runs longer that what the guide shows, will I get the entire game?
What if I select a program which starts after a game (that I am not recording)? Does SageTV detect this and record when the show finally starts (and records the entire show?)
Any help, pointers to prior discussions etc. would be appreciated.
Thanks.
Old 08-11-2009, 10:11 AM
Originally Posted by BostonDriver View Post
Hi,
Thanks.
Nope. This is an issue with most DVR's. What I do (especially during football season) is manually record shows after the game. Also if you setup favorites, you can also adjust the padding (the amount of time recorded after the scheduled time).
Old 08-11-2009, 10:32 AM
MattHelm MattHelm is offline
There is an add on that is suppose to handle this, but I can't remember the name. Someone that uses it, please speak up.
Old 08-11-2009, 10:37 AM
Sage Recording Extender?
Old 08-11-2009, 11:08 AM
pjpjpjpj pjpjpjpj is offline
Hi,
Thanks.
Check the "Sage Recording Extender" plug-in that stanger mentioned, in the "customizations" folder. I've never installed it, but I read up on it a while back - I believe it pulls data from an online site and is able to determine when a sporting event ends, and will continue recording until that point. It has limitations, I am sure, but it's a start. As for adjusting the times of shows that are pushed back after an event, I doubt you will have any luck with that.
Server: AMD Athlon II x4 635 2.9GHz, 8 Gb RAM, Win 8.1 x64, Java 8, Gigabit network
Old 09-03-2009, 11:28 AM
RobJ RobJ is offline
The extension mentioned above will help for sporting events that run long, if the event is sufficiently mainstream, probably American only.
I don't know of any good way to handle the programs that follow. Currently, I believe CBS is the worst offender by far, on Sunday night, throughout football season and perhaps beyond. What I do is add about 50 minutes of padding, and then use VideoRedo to chop and join the pieces, quite a laborious job when it often involves 2 consecutive programs, Cold Case and The Unit if I remember right. I reconstruct the program in another video folder, set the time stamp (possibly not needed any longer), delete the original, and rescan.
Actual Time Timecodes thegodfaza SageTV Customizations 4 06-22-2009 08:45 AM
Adjust Start Time/End Time for consecutive shows GreggP SageTV Software 5 10-16-2007 07:40 AM
Program Guide Update Time? Lastb0isct SageTV EPG Service 2 07-17-2006 09:52 PM
How to disable the popup window in the program guide? How to keep the program guide? metropole SageTV Software 8 05-18-2006 06:25 PM
Cable Box Banner at start of every program Alhead SageTV Software 9 08-25-2005 07:43 AM
