Old 04-20-2017, 06:40 AM
will will is offline
IR Blaster Options
It looks like I'm finally going to have to stop using FireWire for channel changing.
I'm a little confused with which IR blasters work with Sage. My setup is two cable boxes connected through two HD-PVR 1212s.
I know he USB-URIT works but it seems like they aren't for sale anymore. Can anyone recommend something else; preferably something available on Amazon?
Will
OS: Windows 7
Old 04-20-2017, 08:49 AM
brianrent brianrent is offline
Seems it is still available here: http://www.usbuirt.com/
Old 04-20-2017, 08:58 AM
I thought it was sold out.
Still, are there any other USB IR blasters that work with Sage?
Will
OS: Windows 7
Old 04-20-2017, 09:26 AM
This one is IP-based, instead of USB: https://forums.sagetv.com/forums/showthread.php?t=64372
I like that it has three jacks built-in for IR emitters, instead of having to monkey with a RadioShack splitter...
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i3-7100T CPU, 16GB Memory, unRAID 6.3.2, SageTV & OpenDCT Dockers
Old 04-20-2017, 09:51 AM
Tiki's Avatar
Tiki Tiki is offline
Why do you say they aren't available anymore?
You can get them here: http://www.usbuirt.com
,USBUIRT (multi-zone)
Source:
Comcast Cable
HDHR, HVR-2250
Old 04-20-2017, 11:10 AM
Why do you have to stop using FireWire? Moving to 64 bit Windows or STBs that don't have active FireWire?
Old 04-20-2017, 12:56 PM
I must of made a mistake; I could have swore I saw them as not available at one point a few months ago.
I'm moving to a new city and the new cable boxes Time Warner/Spectrum will give me won't have FireWire drivers available. They use Samsung boxes now a days.
I also plan to move to Win 64-bit OS since my OS is old as dirt and since I can't use FireWire there isn't much holding me back (I'd go Linux 100% if my RAID arrays weren't NTFS formatted).
Will
OS: Windows 7
Old 04-20-2017, 01:37 PM
With Linux you can use FireWire but that is irrelevant in your case. There was another IR blaster called something like IR Commander, and this is what stuckless uses, but it isn't being made anymore. That may be why you thought that the USB-UIRT is no longer available. But the good thing is that you can use one USB-UIRT to control all three of your cable boxes.
Old 04-24-2017, 06:57 AM
MacDaddy MacDaddy is offline
I've been using the iTach a few weeks now. It's been rock solid tuning Uverse STBs. I'm moving to HDHR Prime so Uverse will sunset.
I've used the USB-Uirt in my prior Windows environment. It's windows driver was great and Sage support was spot on. However when I discovered the docker approach, the lack of driver support for USB-Uirt (and multi zone) was a non starter. To me, the upside of the iTach was IP addressable, open API, and reputation. The downside is nonstandard IR code representation and having to define your IR command structure outside of Sage. Although if you look at the GENTUNER script you'll find it's not that difficult to set up.
Frankentivo: iStar D-380HB, SuperMicro X107-F-O, Xeon 1270v3 CPU, Kingston 8 GB 1600MHz DDRR3L x 4
Tuners: 4 x HDHR OTA, 4 x HDHR3 OTA, 3 x HDHR Prime
UnRAID Pro: 1 x Samsung 500GB Cache, 5 x WD Red 4TB (1 Parity, 4 Data)
Extenders: 2 x HD-200, 1 x HD-300 on Atlona PRO3HD66m
Sage: V9.0.14.567 with OpenDCT on unRaid docker, Gemstone, BMT, Web UI, PlayOn, TiSage
Old 04-24-2017, 07:40 AM
Thanks for all the help; I just ordered a USB-URIT.
Since I'm planning on controlling two identical cable boxes I'll need to get IR emitters. I understand that the USB-URIT can control two external devices by the 1/8" jack and a third through the built in emitter, is that correct?
Assuming what I'm thinking is correct, will this cable work? https://www.amazon.com/Emitter-Exten.../dp/B01N4NS0WC
Will
OS: Windows 7
Old 04-24-2017, 07:44 AM
Taddeusz Taddeusz is offline
No, that will not work. When I had multiple tuners to control I had two separate IR transmitters and a stereo to L/R mono adapter like this:
https://www.amazon.com/Hosa-YMM-261-...+adapter+3.5mm
Old 04-24-2017, 05:19 PM
The "Y" cable is needed. You also need the version enabled for zone control (the first versions were single only). Plus if I recall correctly you need to precede the IR command with the zone.
Keep in mind this is for windows. In the Linux world the driver for the USB-Uirt supports only single zone.
Old 04-24-2017, 05:22 PM
Rather than using a Y adapter you can use the plug from an old pair of stereo headphones and splice it onto two IR blasters. Ground goes to ground on both IR emitters, tip goes to the + on one of the zones and ring goes to the + on the other zone.
Old 04-25-2017, 08:46 AM
I purchased the version on the website so I hope that is the most recent version and will be dual zone. I believe I found the dual zone setup instructions at https://forums.sagetv.com/forums/sho...16&postcount=9.
Thanks for all the help everyone; this stuff is a little confusing.
Will
OS: Windows 7
Old 12-30-2018, 03:04 PM
Has anyone got the IR blaster on an Hauppauge WinTV2 working?
ASUS P7H55D-EVO LGA 1156 Motherboard, Intel Core I5-661, 2X Crucial Ballistix XMS3 2GB RAM, 2x Mushkin Blackline 4G RAM, EVGA GT 1030SC, 1x Samsung 250g SSD, 1x WD80EFAX 8TB, 2x WDBH2D0040HNC 4TB, USB-UIRT, ASUS Blu-Ray SATA drive, HD-PVR2, WinTV dualHD, Windows 7 64bit
Old 01-02-2019, 10:06 AM
SHS's Avatar
SHS SHS is offline
I never heard of a Hauppauge WinTV2
Old 01-19-2019, 12:39 PM
HD PVR 2
http://www.hauppauge.com/pages/produ...ta_hdpvr2.html
Old 01-26-2019, 01:15 AM
JeffHaas JeffHaas is offline
I have the Colossus 2, the IR blaster works fine. I got a piece of plexiglass and taped the cable box to it, and taped the IR blaster in front of the right spot on the cable box. There is a slight delay while the channel is tuned and the Colossus catches up, so I set up recordings to start 2 minutes early.
malore menus: using the Options command for xml/commercial detect options Opus4 SageTV v7 Customizations 21 06-09-2017 11:32 PM
Video Menu Options instead of Menu Options in SageMC scriptx SageMC Custom Interface 6 03-20-2008 03:07 PM
FF and RW options... Addict SageTV Software 4 05-13-2007 12:33 AM
DVB-S Options AtariJeff General Discussion 9 01-05-2007 07:45 PM
New TV - what are my options garyellis Hardware Support 12 10-20-2006 08:14 PM
