Old 01-08-2021, 06:45 AM
graywolf's Avatar
graywolf graywolf is offline
Green tint on Recordings of B&W shows
Have a HVR-1600 for recording shows. Wife tapes many old B&W westerns and complains about "green tint" instead of being true B&W.
Any thoughts on what might be causing this and actions I might take to get back to true B&W "color"
Old 01-08-2021, 09:21 AM
Tiki's Avatar
Tiki Tiki is offline
Is it only B&W recordings that are tinted or is everything greenish? What type of connection are you making to your tuner ( I think your tuner supports coax as well as S-Video, composite,...)?
Have you tried playing back on a different screen to make sure it is the recordings that are green and not an issue with the tv?
,USBUIRT (multi-zone)
Source:
Comcast/Xfinity X1 Cable
HDHR, HVR-2250, HD-PVR
Old 01-08-2021, 10:56 AM
graywolf's Avatar
S-Video connection
Only appears to be affecting B&W shows, or at least that is only ones wife has complained about.
Played on other TVs still have same "greenish" tint.
Checked tuner color calibration and it is at the Default.
Old 01-08-2021, 12:33 PM
This might be stating the obvious, but do you have any other (better) connection options besides s-video?
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, unRAID 6.9.2, SageTV (java11) & OpenDCT Dockers
Clients: Multiple HD300 Extenders, Multiple Fire TV Stick 4K w/MiniClient
Old 01-08-2021, 01:13 PM
Are these OTA shows that are being recorded directly from the OTA stream? Or are you using a cable box?
I know I get some old shows on a sub-channel broadcasting out of Buffalo. Maybe the original broadcast has that tint. What channel are the shows on, if they are OTA?
Old 01-08-2021, 01:35 PM
graywolf's Avatar
DirecTV Starz Western
DirecTV FETV (Family Entertainment Television)
Old 01-08-2021, 01:39 PM
graywolf's Avatar
Need to refresh my memory and double check the DirecTV box outputs and the HVR-1600 inputs (think coax or s-video)
Old 01-08-2021, 02:08 PM
Tiki's Avatar
I have definitely seen cases where a loose connection or bad cable could result in a green tint, but it affected everything (not just black and white) and it was very noticeable.
I havenít used an analog capture device in years, but I seem to remember there were settings in Sage for calibrating the picture (brightness, tint, etc). They would have been in the source setup menu for the capture device.
It would also be worth seeing what the picture looks like if you bypass Sage entirely and just hook your source up directly to a tv.
Source:
Can I configure the age of green highlighted "recent" shows? Malfunction SageTV Software 0 06-17-2020 10:50 AM
SageTV Recordings - Watched Indicator Green Bar Missing RangerZ SageTV Software 4 07-28-2017 03:55 PM
Hauppauge HD PVR Green Tint Diego Garcia Hardware Support 1 01-08-2012 08:06 PM
Sudeenly Green Screen w/HD-PVR Recordings Savage1701 SageTV Software 0 11-03-2009 02:10 PM
Green and Black lines in recordings JUC SageTV Software 13 06-01-2004 09:43 AM
